Author Topic: dohc engine in a sohc frame?  (Read 2900 times)
Acid0atm3al
« on: January 01, 2009, 11:32:57 PM »
what would have to be done to squeeze a dohc into a sohc frame? just found a crack on a downpipe on my frame, and noticed the framed is REALLY rusted on the inside.
i have a good running low mileage 1980 750k.....and i can get a nice sohc 74 for free with a title, i dont want to screw with the sohc motor, as its locked up and missing alot of parts, but the rest of the bike is mostly complete.
what do you think?
Re: dohc engine in a sohc frame?
« Reply #1 on: January 02, 2009, 12:10:41 AM »
Anything is possible with a gas axe and welder but easy ---No
KingCustomCycles.com
« Reply #2 on: January 02, 2009, 02:53:18 AM »
Look at the value of the finished product when considering a full custom as you suggest.  Is it worth your time at $5.00 an hour? I doubt it.  It sounds like all you need is a few inexpensive parts (frame, engine) to have TWO bikes  ;D
shugsi
« Reply #3 on: January 02, 2009, 03:26:23 AM »
If you already have the SOHC frame and the DOHC motor, why not just have a play about...remove the DOHC motor and see if it will fit in...you have both items at hand so wont cost you anything, you might be surprised...Im considering same idea as you but with a cb650z frame..
Some people have said I should keep it standard but others said go for it....
But I want to build something that "I" want and not what "others" want...no offence to anyone on here.
Let me know if you go down the route of trying the DOHC engine in SOHC frame..
Cheers
Shugsi
« Reply #4 on: January 02, 2009, 03:35:00 AM »
Cheers
Shugsi
Having what others want is the definition of cool.  No offense intended.  Actually, I suggest he go for whatever he wants to do and learn what it takes to make a swap like that.  Which is more valuable, the painting or the painter?  When he gets done, he can wear the Tshirt that says "Custom Bike Builder" with pride in his knowledge and skills.
shugsi
« Reply #5 on: January 02, 2009, 03:51:49 AM »
True...sometimes you just have to "give it a go" and if it goes tits up, then you gave it a shot...nothing ventured nothing gained as they say
Offline mick750F
« Reply #6 on: January 02, 2009, 05:35:36 AM »
  In the past year or so I've seen two sohc frame bikes with dohc  motors on craigslist so I guess it's possible.  ;) I have no idea what mods were involved.
Mike
Glosta, MA
Offline Geeto67
  • A grumpy
« Reply #7 on: January 02, 2009, 09:29:25 AM »
a DOHC cb750 motor is much too tall to fit in the SOHC frame without sectioning the frame to add height. Later DOHC sportbike motors are not as tall.
Maintenance Matters Most
Offline jx25
« Reply #8 on: February 03, 2009, 02:39:13 PM »
i have had this same thought putting a dohc in my sohc frame, Acid0atm3al did attempt anything?  I'd be very interested in the outcome.
1978 CB750K (slightly modified)
1973 Suzuki GT250
1968 Ducati Monza 250(needs title)
1965 Bultaco 250(needs clutch work)
