Author Topic: Tweek bar ?  (Read 6482 times)
Tattoo
Tweek bar ?
« on: January 03, 2009, 03:16:25 AM »
Hi All, Will a tweek bar off of a 74 550F also fit a 350F? Is the twin 350 tubes the same as a 350F? Many thanks Tattoo
KingCustomCycles.com
Re: Tweek bar ?
« Reply #1 on: January 03, 2009, 03:48:07 AM »
What is a "tweek" bar and which tubes?
country bar
crow bar
gay bar
zanzibar
pry bar
spud bar
martini bar
light bar
raised the bar
tweek bar ?
Offline UnCrash
  • Pass
    • My Blog
Re: Tweek bar ?
« Reply #2 on: January 03, 2009, 04:21:04 AM »
I think he's talking about this:
Tattoo
Re: Tweek bar ?
« Reply #3 on: January 03, 2009, 06:49:58 AM »
country bar
crow bar
gay bar
zanzibar
pry bar
spud bar
martini bar
light bar
raised the bar
tweek bar ?
LOL Yes I can see your point. But you have a photo of a custom bike in your profile so I would think you should know. LOL. It's the brace between the fork tubes like the nice guys photo shows.  8) Tattoo
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
Re: Tweek bar ?
« Reply #4 on: January 03, 2009, 08:18:19 AM »
Actually, that's a fork brace (mounts to the lower sliders).
  A tweek bar mounts directly on the fork tubes to strengthen up the forks (usually on extended forks).
 Like this.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Re: Tweek bar ?
« Reply #5 on: January 03, 2009, 08:59:01 AM »
I have one of those !!! It was on a CB750 Chopper abomination I bought.  It now resides in a box in my garage.  Check out  http://kingcustomcycles.com/home.html (my site) for a whole bunch more Bobbers and Honda Projects.  To answer your question on the tubes, same diameter I am certain, length I am not 100% sure.
Offline fishhead
Re: Tweek bar ?
« Reply #6 on: January 03, 2009, 09:29:40 AM »
The hole spacing(fork to fork) also has to be correct along with the fork tube diameter.
Re: Tweek bar ?
« Reply #7 on: January 03, 2009, 09:33:22 AM »
Hmmm.. bike builders that dont know what a tweek bar is??
tings are different these days...
I had a customer that had a really long front end, wideglide about 16 or 18 over. He did not want to mess up the lines of the forks with a tweak bar so we built a brace for the stock type 21 inch fender.. out of 1/4 6061..
we bent and we bent and we bent.. til we got it pretty much like the stock mount. maybe a bit of sanding to help the curve, but no cutouts like stock and WAYYYY stiffer.. it probably helped a lot..
If you make a brace like beemers used, like a double horseshoe, with flat bar in between, I think is the stiffest you will find.. or the even easier to build type like I have on my green 73 750 ..(an afternoon project)
Re: Tweek bar ?
« Reply #8 on: January 03, 2009, 09:38:52 AM »
Modern sportbikes use a metal horseshoe inside the fender in most cases.  Less clutter and easier to fab.  No doubt stiffer also as they are 4 or more inches wide.
Tattoo
Re: Tweek bar ?
« Reply #9 on: January 03, 2009, 12:43:57 PM »
I guess another question to ask is the tripple trees the same on a 550 as a 350? You know the things the tubes slide through that the handle bars mount to? LOL  8) Tattoo
Offline cb750-bobber
  • With age, comes character...I support vintage!
Re: Tweek bar ?
« Reply #10 on: March 02, 2012, 02:39:44 PM »
Let's fire this thread back up, I'm hoping 754 knows...I have a stock front end with a cycleX boxer frame..it appears to be raked a little..Which would do me better? a fork brace or a tweek bar? I am suffering from some front end wobble entering any corner where lean is needed. FYI i have NO front fender an a single caliper front brake set-up.thanks in advance.
« Last Edit: March 02, 2012, 02:42:00 PM by cb750-bobber »
Re: Tweek bar ?
« Reply #11 on: March 02, 2012, 08:06:24 PM »
Tweak bars are for extended forks. For stock length forks, a fork brace is used. If you have a wobble merely leaning into a mild turn, I would take a good look at the wheel alignment!!
Re: Tweek bar ?
« Reply #12 on: March 02, 2012, 08:43:36 PM »
 Let me guess, are your trees chromed ? that dragrace style brace I built is pretty stiff... 1080 posted a thread about one he made..
edit for Type O's   :o
« Last Edit: March 02, 2012, 09:12:05 PM by 754 »
Re: Tweek bar ?
« Reply #13 on: March 02, 2012, 08:56:20 PM »
country bar
crow bar
gay bar
zanzibar
pry bar
spud bar
martini bar
light bar
raised the bar
tweek bar ?
LOL! Guess a leopard never changes his spots. Name maybe... ::)
Re: Tweek bar ?
« Reply #14 on: March 02, 2012, 09:40:40 PM »
He forgot whiskey bar!
Re: Tweek bar ?
« Reply #15 on: March 02, 2012, 09:54:22 PM »
Not to mention boring bar, beer bar, wine bar, and buss bar. ;)
Forgot breaker bar, and torsion bar.
« Last Edit: March 02, 2012, 10:08:17 PM by scottly »
Re: Tweek bar ?
« Reply #16 on: March 03, 2012, 01:23:40 AM »
Chocolate bar anyone..?
Re: Tweek bar ?
« Reply #17 on: March 03, 2012, 01:29:07 AM »
bull bar/nudge bar,,nudie bar,foobar?
« Last Edit: March 03, 2012, 01:32:41 AM by dave500 »
Re: Tweek bar ?
« Reply #18 on: March 03, 2012, 01:39:42 AM »
Fubar?
Re: Tweek bar ?
« Reply #19 on: March 03, 2012, 08:03:13 AM »
Offline srbakker
  • Spam & Eggs
Re: Tweek bar ?
« Reply #20 on: March 04, 2012, 11:17:21 AM »
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
Offline andrewk
  • doin' it.
Re: Tweek bar ?
« Reply #21 on: March 04, 2012, 01:28:22 PM »
That was my thought exactly. :P
Re: Tweek bar ?
« Reply #22 on: March 04, 2012, 05:47:05 PM »
Tiki bar
Offline Tews19
  • I am no
Re: Tweek bar ?
« Reply #23 on: March 04, 2012, 06:15:35 PM »
Tittie bar?
1970 Honda CB750 survivor.
Re: Tweek bar ?
« Reply #24 on: March 04, 2012, 09:42:03 PM »
hershey bar?
