Author Topic: Need Verification: This is What I Need to Remove & Lap Valves? CB350F  (Read 1957 times)
Offline OakBehringer
Before I put in my order I'd like to make sure that I've chosen the right valve spring compressor and lapping compound. Here's what I've picked out:
https://www.partshighway.com/product.php?productid=99783
https://www.partshighway.com/product.php?productid=99788
https://www.partshighway.com/product.php?productid=99785
I tried to get this stuff at both my local Pep Boys and Autobone, none of which could be found. I was also asked by an employee "valve lapping? wut dus dat do? sumtin for tires?"
Anyway, if anyone has a recommendation for a better place to order from, I'm all ears. I chose this place because it had very high reviews on Google Shopping.
Thanks!
Adam
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline scunny
  • don't call me expert
Re: Need Verification: This is What I Need to Remove & Lap Valves? CB350F
« Reply #1 on: January 03, 2009, 06:05:14 PM »
can't see any problems using that gear.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline tomkimberly
« Reply #2 on: January 03, 2009, 06:34:43 PM »
That valve spring compressor is too big to use on the CB350F.
Check out the other thread on spring compressors.
Tom
WHALEMAN
« Reply #3 on: January 03, 2009, 06:36:35 PM »
Looks good Oak. The only thing I would do different is to borrow the compresser from the local Autozone once to remove and once to put back, but I am cheap and drive by it every day. Make sure you clean all the compound out real good before reassembly. I assume you will clean all the carbon from the valves before lapping. Dan
« Reply #4 on: January 04, 2009, 12:00:10 PM »
Tom
Tom, which thread is that? I searched like crazy before I posted.
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline tomkimberly
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #7 on: January 04, 2009, 07:36:08 PM »
if you are going for the sportingforless one I have an identical one and it is perfect for the job, I have also bought the shock absorber spring compressor from them which is good too.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
« Reply #8 on: January 04, 2009, 07:56:07 PM »
Dont just put the compressor on and wind the bolt! Lay head gasket face down on thick cardboard , find a standard socket that fits the top collar and hold it on then tap the other end of the socket with a hammer. This will loosen the grip of the top collar on the tapered collets.
WARNING
Dont hit too hard or you may "jolt" the collets out and watch them fly accross the workshop to another planet
Offline mmtsquid
« Reply #9 on: January 05, 2009, 05:18:23 AM »
After searching every parts store for miles around, I just made a valve spring compressor - bic C clamp and a piece of thin wall steel tubing (it was a mop handle in it's former life).  I cut a window out of the tube so I could get to the keepers with needle nose pliers, and it works great - total cost $4.00.
77 CB550K4
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #10 on: January 05, 2009, 05:29:31 AM »
Rod Gibson showed how to make a valve spring compressor out of an old G-Clamp in Classic & Motorcycle Mechanics a few months back.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline crazypj
  • I'm brill, me
« Reply #11 on: January 05, 2009, 06:46:08 AM »
WARNING
Don't hit too hard or you may "jolt" the collets out and watch them fly across the workshop to another planet
 ...and don't hit it hard enough to move valves down onto worktop as you can bend them.
 If you've never lapped valves before be very careful, the face hardening is pretty thick on early ones  but it is possible to cup faces.
 Personally I haven't lapped valves for at least 15 yrs, if seats are nasty they need cleaning up properly, if things are OK and not leaking, leave them alone
PJ
taymoor
« Reply #12 on: April 15, 2009, 05:41:22 PM »
I didn't use a valve spring compressor on mine...
Its a two man job, but I used the closed end of a wrench to push down the valve spring, while a neighbor used a magnet on a stick to pull out the retainers.  much easier this way.
Offline heffay
« Reply #13 on: April 15, 2009, 09:30:16 PM »
until someone loses a finger or an eye.   ;)  < see there... lost one already!
taymoor
« Reply #14 on: April 16, 2009, 07:40:22 PM »
luckily the good Lord blessed me with a spare! :P
