Author Topic: 21 inch cafe?  (Read 62120 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: 21 inch rear wheel cafe?
« Reply #225 on: January 25, 2009, 12:31:34 PM »
Looks good, but like bouncer said, "a little tight", that's why I wanna stretch it a few inches.
but thanks for the physical mock up. It's always better than photoshop.
I measured a friends 21, it measured out to 28 inches floor to top of the 90/90.
I picked up a DOHC swing arm with all the hardware for $45 shipped.
Now I just gotta get the 21 inch hoops, some laces, and a rear hub.
I dropped my spare, and cracked the lip off... :(
once I get it all together I'll post a new thread showing the progress.
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #226 on: January 25, 2009, 01:02:11 PM »
I think I have a 21 here somewhere....
had front drum.... but no back plate for the shoes.
If you want it let me know. I know I'm not gonna use it.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
  • Like a well oiled
    • Undead Asphalt
« Reply #227 on: January 25, 2009, 04:33:17 PM »
hmm...
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
« Reply #228 on: July 13, 2009, 09:10:42 AM »
Wanted to bring this one back from the dead. Still looking for info on doing a 19' rear shoulder dirt wheel on a '78 cb750 for a flat track set-up. Anybody have a bolt-up conversion?
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
  • Like a well oiled
    • Undead Asphalt
« Reply #229 on: July 13, 2009, 09:17:01 AM »
aaaaaack! I think it was dunstall that used to put 19's on the back...
but it might've been tracy.
                                       buchanan spokes will make you a set to got from your rear hub to the 19 wheel for $120 they have it all in the computer, just tell them the inside measurement from spoke hole to spoke hole and what the hub is off of.
I've been on hold with the 21'' wheel project due to lack of funding.
     but I have confiscated a pair of hoops from a friend of mine for screwing me out of 80 bucks, so now I have rims and a front hub.
I talked to a member a few months ago and he had a rear hub assy for me, but I lost his messages. :(
« Reply #230 on: July 13, 2009, 09:19:36 AM »
Kev, are you talking with the drum, or the disc?
 Start scouting wreckers around you for them Canam Betors, early type with axle in the middle..
Offline HavocTurbo
  • Can you tell?
« Reply #231 on: July 13, 2009, 09:19:59 AM »
I'd look through some dirt wheels from the 70-80-90's. Rears can be had in multitudes of sizes.
That way you can also get rear disc brakes as well as a slightly hard sprocket carrier set-up for really getting on it.
Wears through sprockets pretty quick though.
09 XL883L - No Name
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #232 on: July 13, 2009, 01:45:53 PM »
How quick? I put about 300+ miles on my bike a week right now. :o
Offline HavocTurbo
  • Can you tell?
« Reply #233 on: July 13, 2009, 01:51:57 PM »
Depends on how hard you shift... transition from clutch to throttle from a stop.
Also cornering throttle is a big sprocket eater as well as engine braking.
If you are riding a stock 750/550 etc and want to go to a dirt rear hub you'll be fine.
Probably get a couple of seasons out of a standard steel sprocket. Maybe 2-3 out of aluminum.
Depends on the brand and metal quality. And chain quality as well.
09 XL883L - No Name
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #234 on: July 13, 2009, 08:39:43 PM »
Alright, so looking at the Mule site, it looks like he's running 18's front and back and a taller tire:
http://mulemotorcycles.net/motorcycle-parts-for-sale.html
sounds alot easier for the look/price/time.
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #235 on: July 14, 2009, 05:00:21 AM »
Those Morris wheel are missing the bearing carriers and would need to be made up or located (not an easy thing to find). The bearing carriers bolt to the sides of the wheel and are needed to put bearings in the wheel.
Heres a pic of a KZ 900 Morris front wheel. It shows the bearing carrier mounted in it.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
« Reply #236 on: July 14, 2009, 08:54:35 AM »
See Fish, small center rib, on that one , just like my 4 bolt one..look at the bottom of pic where valve stem passes thru..
 But some of the others,  dont have it.
Offline aaronxs400
Re: 21 inch cafe?
« Reply #237 on: June 30, 2010, 11:10:12 AM »
i know this is a really old thread, but check out htis bike:
cafe with 23" wheels!
Horton Customs Mono-shocked 550 Bobber
1982 Yamaha XS400 Soon-to-be Cafe
1994 Harley Sportster Dragbike (10.72@128)
My Album: http://www.sohc4.us/gallery/v/members/personal/aaronxs400/
  • Like a well oiled
    • Undead Asphalt
Re: 21 inch cafe?
« Reply #238 on: June 30, 2010, 12:37:39 PM »
that's a bad ass dirt cafe.
Offline aaronxs400
Re: 21 inch cafe?
« Reply #239 on: June 30, 2010, 07:23:11 PM »
how far did you get with yours industrial cafe??
  • Like a well oiled
    • Undead Asphalt
Re: 21 inch cafe?
« Reply #240 on: June 30, 2010, 07:56:00 PM »
I got to the planning and pricing stage when I was distracted by a gixxer front end swap that changed the direction of the bike.
13
Re: 21 inch cafe?
« Reply #241 on: February 04, 2011, 01:16:06 AM »
forgive me, I didn't read all the posts on the thread.....
anyway, I built a triumph Thunderbird bobber, with a 21'' rear wheel.  did some frame mods, and extend the stock swingarm kept stock shock locations, just cut in the between the  mounts and axle and added some steel.  took stock rear hub, and a 21'' front and laced it to fit hub.
took a while to find someone to help me out and believe it wasn't a retarded idea... but it came out awesome.  hope I can throw up some pics.
01 triumph TB, 900cc liquid cooled triple, carbed, foot clutch, jockey shift behind the leg. clip on bars, and that's a bout it....  she's a beast. down 3 teeth on front sprocket, and up 5 on the rear to roll off the line with a purpose. had to eventually upgrade suspension front and rear to handle better.
low sided the bike 2 years ago, and has been sitting since.  snapped shift rod inside the case, and have to split the motor to replace it. , but have time to do so now, will get it up and running and let you know how it goes.
  • Like a well oiled
    • Undead Asphalt
Re: 21 inch cafe?
« Reply #242 on: February 05, 2011, 08:26:27 AM »
sounds cool, throw up some pics!
Offline gerhed
« Reply #243 on: February 05, 2011, 09:18:27 AM »
I did a 21'' front wheel on my old CB750 --->
The next bike I build (that will actually run under it's own power) will def. be more of a board tracker setup, with either as 23'' front and 21'' rear or something
along those lines.. That bike above is def. sweet. Gotta give a bike props for looking like it's going fast when it's standing still...
Pro,
Did I see you in the "Cafe Racer" TV series episode that was in Chicago.
What's the story?
ghd
          83 XL600R in CB360 Frame
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #244 on: September 11, 2014, 04:17:33 PM »
Pro,
What's the story?
ghd
Um, maybe  :D
Offline lucky
Re: 21 inch cafe?
« Reply #245 on: September 11, 2014, 04:45:52 PM »
is it so ridiculous?
has anyone ever seen this?
i wanna try it, to see what it'd look like on a cb750 cafe bike
i stuffed together a list of mods:
4 inch stretch swing arm
112 or so link chain
tall shocks to compensate for the length of the swingarm or relocate the mounting points
long spokes (dunno where to get spokes for a 21 inch wheel to a cb750 hub)
and a 21x2.25 inch rim
heres what gave me the idea
oh god thats sexy
I see no photo. So I do not like this. LOL..lol.
 A 21 inch front wheel is only about 1 inch taller over all with tire. Not a big deal.
Offline Lostboy Steve
Re: 21 inch cafe?
« Reply #246 on: September 12, 2014, 05:32:28 AM »
Oh yes, Please, and while you're at it, tell me more about your road glide with a 21" front wheel. Blah. Looks weak in my opinion, but as they say opinions are like #$%*s.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
