Author Topic: can i soak an entire engine in kerosene?  (Read 2157 times)
Offline 547
« on: January 06, 2009, 04:33:11 PM »
i have this '69 cb160 with a seized engine and my step dad told me to try soaking the engine in kerosene.
can that be done? if so should i turn it upside down in the kerosene to keep the transmission and the starter
motor out of it all?
any info would be great
j-
Offline cbr-eric
Re: can i soak an entire engine in kerosene?
« Reply #1 on: January 06, 2009, 04:34:57 PM »
try marvel mystery oil first, I have seen it free up a lot of frozen parts and a few real stuck motors!
k8 project, a long way from done.....
Offline 547
« Reply #2 on: January 06, 2009, 04:36:53 PM »
i used marvel to free up my cb750. i have considered that for this engine but thought this might work better.
j-
Offline cbr-eric
« Reply #3 on: January 06, 2009, 04:45:47 PM »
it it works, why change? :)  besides, if you get kerosene some places you might be hurting things (like you are worried about the tranny) but marvel really shouldn't hurt anything.  just dump the stuff in the cylinders and see what happens. worth a shot, no? hell of a lot easier too :)
Offline markjenn
  • CB750K1, CBX, RC30
    • Whizmo and Gizmo
« Reply #4 on: January 06, 2009, 04:47:24 PM »
If it's rusted bores, it seems kinda drastic to soak the whole engine when all you want is to get the solvent in the cyilnder bores which can be done easily via the spark plug holes.  Further, putting the engine upside down in solvent is not using gravity to get the solvent where you want it.  If its more than this that is seized up, then the motor is a write off.
- Mark
Offline aptech77
« Reply #5 on: January 06, 2009, 06:51:36 PM »
Or try Kroil.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #6 on: January 06, 2009, 06:56:07 PM »
i washed an entire bottom end of a cb350T in my parts washer. it wasn't soaked (i put the brush in the top of the case and let if flow for several hours though), but but got rinsed pretty well with parts washing fluid. my parts washer always has a little residual oil which probably helped prevent any surface rusting in the gearbox. i'd say if you do try soaking it, mist the inside with some kind of light oil immediately after drying it.
on the other hand, it's not that hard to split the cases on a 160...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
