Author Topic: What it required to build the Hot Rod engine...  (Read 5939 times)
Offline sparty
  • I just play one on TV
    • Gallery
« on: January 07, 2009, 08:53:27 AM »
A few guys asked me to post this information.  I finally had time to type it up.
As you can see, nothing went untouched  ;D
Top End Parts and Labor:
Megacycle 125-75 Cam
Megacycle Adj. Camshaft Sprocket
Kibblewhite Ti Valve spring retainers
Kibblewhite H-D racing valve spring springs and retainers
Kibblewhite bronze valve guides
EV8 Polished SS oversized intake valves 33.5mm
EV8 Polished SS exhaust valves 28mm
New OEM Honda Rocker Arms
New OEM Honda valve seals
Tsubaki H-D cam chain
M3 Racing can chain tensioner
APE H-D Top End Studs
JMR Stage 3 Head porting, polish, and mill
Serdi valve job
Head bead blasted
New OEM Honda intake manifolds + modified air fittings
New OEM Honda Intake manifold clamps
Balanced Alt. rotor and clutch basket
Cut & polish SS allen bolt head set
Bottom End Parts and Labor:
Wiesco 836cc Piston Kit
Falicon Knife Edge connecting rods with ARP premium bolts
New OEM Honda cam bearings
New OEM Rod bearings
Swain Tech piston coatings (TBC & PC-9)
APE H-D Bottom end bolt kit
JMR Cylinder decking (total squish .053)
New OEM Honda primary chain tensioner
JMR Bore and Hone cylinders (top cut .014 and recut o’ring c’bores)
APE lightened and balanced crankshaft (balanced for sustained operation to 14,000RPM)
Barnett H-D clutch springs
New OEM Honda clutch fibers and disks
FAST by GAST undercut transmission
New OEM Honda gaskets and oil seals, dowels, misc. parts
Bead blast cylinder head
Paint engine case
Polish all side covers and cam cover
New OEM Honda bolts for engine case
Rocker arm threaded adjusters
New OEM Honda cam guide
Fuel and Ignition Parts:
Keihin CR carbs 29mm
Dyna 2000 electronic ignition w/ 3 ohm coils
Dyna suppression wires
Denso Iridium plugs
K&N Oval air pods
K&N crankcase filter
The sum of all the above: 90+ HP and a big  ;D
Art
« Last Edit: January 07, 2009, 05:46:11 PM by sparty »
1972 CB750 K2 Cafe' Style
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: What it required to build the Hot Rod engine...
« Reply #1 on: January 07, 2009, 08:58:08 AM »
Remind us what it looked like, please.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline sparty
    • Gallery
« Reply #2 on: January 07, 2009, 09:05:20 AM »
From this:
To this:
Offline Really?
« Reply #3 on: January 07, 2009, 09:15:38 AM »
That just goes to show what effect this place and these bikes have on ya, geez!   ;D ;D ;D
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline scondon
  • Mmmm......tasty bugs
« Reply #4 on: January 07, 2009, 09:27:53 AM »
 You forgot to list the "shovel", Sparty. The one used to keep the build fund fires well stoked with green. Some can only dream, but you....you did it. Thank you ;) :) :) :)
Offline nickjtc
« Reply #5 on: January 07, 2009, 09:47:43 AM »
I kneel in awe before the altar of a master. ;)
1977 Suzuki GS750
Offline sparty
    • Gallery
« Reply #6 on: January 07, 2009, 06:04:50 PM »
You know the world is ending in 2012 so you need to make those dreams come true.
I started a small side business 6 years ago to fund my dreams.  Now I am starting to gather parts for my next come true dream - the '32 Deuce roadster RAT ROD.  But it looks like it will not be finished until 2013. :-\  Damn those Roush engines are expensive!
Art
« Reply #7 on: January 07, 2009, 07:16:17 PM »
And it looked as good in person Art! I can only wait until I see the running bike ;-)
Looking forward to the Hot Rod build!
cheers
Andy
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #8 on: January 07, 2009, 07:37:48 PM »
how much are those falicon rods, for a set?
« Reply #9 on: January 07, 2009, 10:55:11 PM »
Art,
It's been a somewhat boring and uneventful winter without you and Seaweb  ;)
Have you thought about picking up a used Roush Nascar engine?
Do you have a final $/HP (dollar per HP) figure?
WHALEMAN
« Reply #10 on: January 08, 2009, 05:09:18 AM »
What is the brand and model of your shocks used in your build and do you like them? Dan
Offline sparty
    • Gallery
« Reply #11 on: January 08, 2009, 07:32:24 AM »
The shocks are YSS Z-366 TRL
They are a bit of overkill, but so is everything else on the bike.  ;D
My wife nicknamed me "overkill" when we met 10 years ago, because she believes that anything that I fix, install, build, buy, modify, research, or just do is done to the extreme.  I however think that this is only one way to do things.
Offline sparty
    • Gallery
« Reply #12 on: January 08, 2009, 07:36:51 AM »
Art,
I never considered picking up a used Roush Nascar engine, I may look into it.
Final $/HP figure = PRICELESS
fuzzybutt
« Reply #13 on: January 08, 2009, 07:37:40 AM »
Art
c'mon art, it needs a flathead!
 seriously though, is the hotrod motor happy on pump gas?
Offline ekim98
« Reply #14 on: January 08, 2009, 09:43:21 AM »
 Geez, I though you were really going to build something that runs great. ::) Only a 30+ HP gain, like why even bother. :) I was happy just to get mine running good and your just taking all the thunder. Excellent job Sparty. 8)
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #15 on: January 08, 2009, 10:18:56 AM »
only +30HP? i got +35 out of the 718...  ;D  ;)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
« Reply #16 on: January 08, 2009, 10:44:03 AM »
i think my favorite part of the hot rod , is the that you got the carpy gauge faces, ... but not the ones that say "cafe" on um ....        i didn't even know carpy did that until your bike
and yes ,  a Deuce needs a flathead , (or a Rocket)
« Reply #17 on: January 08, 2009, 11:02:28 AM »
I'd say well over a 40HP gain as the stock 750 is lucky to have 50HP to the rear wheel on it's best day. Over an 80% increase in rear wheel HP with only a 14% increase in capacity....that's the important part.
Offline paulages
  • 1976 cb735
« Reply #18 on: January 08, 2009, 11:11:15 AM »
mike- i know you were the one i was actually teasing... believe me, i know that engine would spank mine up and down the block.  ;)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #19 on: January 08, 2009, 11:23:46 AM »
Sure Paul. ;) ;) ;D Seeing how Art weighs about 155lbs he would beat me too. ;)
Offline lordmoonpie
    • Moonpie
« Reply #20 on: January 08, 2009, 12:33:24 PM »
C'mon Art - you got to give us a $/HP figure....if your wife likes extreme overkill maybe she'd take a shine to some of us  ;D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline Jim F
  • go baby go
« Reply #21 on: January 08, 2009, 01:08:53 PM »
Well................you guys know the old saying?
Speed costs.................how fast do you want to go
He spent the money OK
This motor should just rip
wow
Big-Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline sparty
    • Gallery
« Reply #22 on: January 08, 2009, 01:23:35 PM »
Okay, calculator is in hand, going though costs of just the engine build....  looks like $77.00 per HP.  Damn, now I see just how much money it took... still PRICELESS as few others have what I have.  Now, I am figuring the cost of the 32' Deuce Rat Rod $/HP.  Let's see... I would like a 500 HP engine so..... looks like about $90.00 per HP.  Heck the CB HOT ROD is a bargain. ;D
Offline ekim98
« Reply #23 on: January 08, 2009, 01:39:27 PM »
Even based on 65/67 hp at the crank a 30+ hp increase is nothing to sneeze at in my book. Plus the added reliabilty with the upgraded studs, chains,blanceing<sp? and the quicker reving abilty gives him one hell of an overall increase in performance across the board. I figure next year we might get a better idea just how much he can get from all the work that has been done. If he can afford the tires he will go thru. And yes I'm jealous. :P
« Reply #24 on: January 08, 2009, 03:54:56 PM »
Yep. He already put the bike in the 11's if I remember correctly and that was on a cold track and it was his first time doing it. ;)
