Author Topic: can i run radial tires on my aluminum spoked rims with tubes?  (Read 758 times)
Dvendivel
« on: January 08, 2009, 07:24:32 PM »
I have a 72 cb750K and a 75 cb750F. They both have aluminum spoked wheels. I was told i could run radial tires with tubes in them. I've seen radial tubes out there, but none in my size. i'd like to get the better performance from the radial and I was told all this was possible, but i'd like some advice.
should i just stick with the bias or will the radials with regular inner tubes work great?
Thanks, Donnie
fuzzybutt
Re: can i run radial tires on my aluminum spoked rims with tubes?
« Reply #1 on: January 08, 2009, 08:15:57 PM »
i run radial bridgestones with tubes on my k4 750 with no trouble at all.
Offline rhinoracer
« Reply #2 on: January 08, 2009, 09:02:32 PM »
With stock width rims? What size tires? The radials I've seen use wider rims
Baja native.
Dvendivel
« Reply #3 on: January 08, 2009, 09:27:53 PM »
fuzzy, are you using standard tubes or radial specific tubes?
stock rims i believe. 19x3 front with 100/90-19 tire, 18x3.5 rear with 130/80-18 tire. to get the radials, I'll need to figure out how to fit a 110 up front. would love to stuff a 150 in the rear.
