Author Topic: soaking a fully assembled head???  (Read 1562 times)
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« on: January 10, 2009, 08:42:54 AM »
hey guys, I got my top end apart and im looking at cleaning things up now. does anyone know if soaking the head fully assembled is a bad thing? I was thinking about getting a bin and simple green and soaking it for a while. is there any negative effects of doing this???
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
Offline Short Round
Re: soaking a fully assembled head???
« Reply #1 on: January 10, 2009, 09:57:42 AM »
How do the valves look? if you have the head off the motor I would go ahead and remove the valves, and have them relapped with new seals.  I'm not sure if simple green will effect the valve seals or not but I would have to go ahead and be a skeptic.  other than the seals it shouldn't hurt a thing, hope this helps...............Chris
1974 CB550
Offline 1timduke
  • '75 CB550
« Reply #2 on: January 10, 2009, 11:24:24 AM »
+1 on removing the valves and lapping...What was the reason for taking the head off???   Did you have a problem or just wintertime curiosity?   ;D                        -Tim
The only thing I miss about the South is Waffle House!
« Reply #3 on: January 10, 2009, 11:36:15 AM »
no problems, there was an oil leak coming from an undetermined area. so I am doing a top end gasket job/cleaning things up. here is what the head is looking like:
all bearing surfaces look great, cylinders are in great shape, i measured the end gap on the top ring in cylinder 1 and it measured out to .48mm max is .6mm or was it .048mm and .06mm? it was within spec.
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #4 on: January 10, 2009, 11:41:40 AM »
 I'd say the oil leaks are coming from the oil return galleys. You should at least change the guide seals while it is apart.
« Reply #5 on: January 10, 2009, 03:41:22 PM »
the valves have been removed and seals are going to be replaced. thanks for the advice guys. ill pull the seals in a little while and soak the head after i scrub the soaking cylinders for the last time. then i will lap the valves and start re assembling.
VISIT OUR WEBSITE!
Facebook:
Instagram:
