Author Topic: Fork oil mixture  (Read 2588 times)
Offline Hush
Fork oil mixture
« on: January 13, 2009, 03:28:15 AM »
Hey guys, gals'n geniuses.
I'm rebuilding a bike and the book reccomends using a 50/50 mixture of fork oil and 19w/40 engine oil?
This seems to me to be something akin to witchcraft!
Surely I would be better using just fork oil.....right?
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: Fork oil mixture
« Reply #1 on: January 13, 2009, 04:57:34 AM »
Which book is that?
Fork oil for forks!
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Soos
« Reply #2 on: January 13, 2009, 05:12:23 AM »
Really?
My cb650 manual states ATF fluid may be substituted in place of fork oil.
(and thats what I use BTW)
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
KingCustomCycles.com
« Reply #3 on: January 13, 2009, 05:13:03 AM »
I use 10w30 with a dash of marvel mystery oil to reduce corrosion and thin viscosity.  I have also used ATF with good results.  I could just go to my local Honda dealer and pony up the cash for "approved" slick stuff and rest better at night.  Most of my bikes arrived at my door with a combination of metal wear particles and dirt, held in a suspension of water and sludge for the last 25 years.  What do I know though..... ;)
« Reply #4 on: January 13, 2009, 05:13:47 AM »
That 19w/40 oil must be worth a fortune!  ;D
Maybe that's what the old fish oil used to be....
My favorite is the teflon-laced oils. Moly would also be good, but holds water more. 10w oil is sufficient, unless the load is over 200 lbs and the speeds are high, then a multi-weight is a little better. Don't use 10w40 unless you have strong forearms though: the shocks get mighty stiff in the mornings with the real wide-range oils.
Slick-ier is better, makes the forks respond over small bumps easier, once is spreads around inside the seals and parts. ATF is the right viscosity, but kinda 'sticky' in sliding parts (it's made for rotating parts, mostly).
« Last Edit: January 13, 2009, 05:19:16 AM by HondaMan »
    • TVAM
« Reply #5 on: January 13, 2009, 05:17:29 AM »
I know nothing...   which is why I moderate and don't make a fool of myself by trying to answer tech questions...
But. (you knew that was coming, right?)
Forks don't get hot so why use a multigrade?
If you want to thin viscosity, don't you use a thinner oil (like 15W for example?)
OMG!
I think I may have just started another "oil" thread...  ;D
SOHC4 Member #2393
2015 Tiger 800 XRT
« Reply #6 on: January 13, 2009, 05:20:17 AM »
OMG!
Oh, no! Someone pull out that fuse! Quick!  :o
Offline Jonesy
  • Shop Rat
« Reply #7 on: January 13, 2009, 05:20:28 AM »
According to the Haynes CB750 Repair manual, The earlier-style forks on the CB750 (with the replaceable bushings) use 10W-40, whereas the later design specified ATF per the owner's manual.
I have a K1 owners manual... I might look up what it recommends for "early" forks...
« Reply #8 on: January 13, 2009, 05:21:28 AM »
OMG!
Cause 10w30 is what my Tercel uses and I have a case on hand. I am a fool daily, I finally got used to it.  Not bad for an aeronautical professor huh?   ;D
« Last Edit: January 13, 2009, 05:23:12 AM by KingCustomCycles.com »
bikerdave47
« Reply #9 on: January 13, 2009, 06:49:30 AM »
As original purchaser of a K2, manual calls for 7 oz. of 10w30 per fork...
Offline hcritz
« Reply #10 on: January 13, 2009, 07:20:27 AM »
Another Oil Thread...Ewwwwwww!
I've done the same as some of you...a witche's brew of ATF and Marvels with a splash of PFTE (slick 50 or generic version) in my k7.
The Teflon really does help the stiction and give a smoother ride.
Hey Mark!
How are things in CO???
Offline Jonesy
  • Shop Rat
« Reply #11 on: January 13, 2009, 12:07:39 PM »
10W-30.. I was close. Thanks for verifying.
Offline Hush
« Reply #12 on: January 13, 2009, 12:53:12 PM »
Er yeah sorry guys you know I meant 10w/40 eh?
Typing in the dark at midnight will cause such erronious statements to occur.
The bike is an 82 Suzuki but the manual I have is a Haynes and yes it states a 50/50 mixture of 10w/40 and fork oil.
I'm confused now as to what to use?
It took me 2 weeks to figure out that 160cc was same as 160mls and that (according to Google) is a coffee cup full!
Offline cbr-eric
« Reply #13 on: January 13, 2009, 03:55:11 PM »
I actually had REALLY good luck with actual fork oil, spectro I think, in my other bikes.  with the change the front end actually seemed noticeably smoother. could just have been the fresh fluid, or the fact I went a little thinner than what was called for (5w instead of 10w)  but either way, it doesnt cost that much and does seem really smooth :)
k8 project, a long way from done.....
« Reply #14 on: January 13, 2009, 06:14:55 PM »
Hey Mark!
Hi, "H"!
I'm freezing parts of my anatomy off, and I wore out my snow shovel (does that mean winter is over now, no more snow?). I can't uncover any of the Hondaman Specials in back, because their tarps are all frozen to the patio. So, I'm rebuilding swingarms, at least when I can get the garage up to 40 degr-r-res or better.
How's it in Winter WondeRiderland? (I'm SO jealous...)
Offline Hush
« Reply #15 on: January 14, 2009, 02:41:58 AM »
Are you saying it's cold HM? I had to go buy another fan just so I could sleep here in NZ, 30 degrees plus and Jan aint our hotest month!!
