Author Topic: CB750 gas cap pin?  (Read 3920 times)
Offline slowjo
CB750 gas cap pin?
« on: January 15, 2009, 02:37:37 PM »
I want to replace the gas cap on my 71 CB750 k2. Does anybody sell just the pin or do I have to buy something like a complete latch kit on eBay? Or can I make one myself using some sort of small bolt? Thanks.
KingCustomCycles.com
Re: CB750 gas cap pin?
« Reply #1 on: January 15, 2009, 02:45:46 PM »
It is a roll pin of metric size I am sure.  Check the nearest ACE Hardware or a used parts shop.  A junk tank will have just such an item hopefully for free.
Offline slowjo
« Reply #2 on: January 15, 2009, 02:53:30 PM »
I do have a spare tank, but how do I remove the pin without doing any damage to it? And can it be reused?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: January 15, 2009, 02:54:25 PM »
I seem to recall "Hondaman" was selling kits for both the cap hinge pin as well as the latch. I believe they were threaded stainless with a small nut. You might want to PM him.
Offline Johnie
« Reply #4 on: January 15, 2009, 03:54:46 PM »
I did remove my cap pin very carefully.  You have to be careful not to bend the cap hinge.  I got a real thin punch and started it that way but did not like the pounding.  So I used a thin steel lock pin and a C clamp to push it through the hole.  When I reinstalled it, I used a BB on the C clamp to crimp the edge over again.  Worked fine, just take your time and put some protection on the tank so you do not ding it up.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Steve_K
« Reply #5 on: January 15, 2009, 04:35:01 PM »
I have used a cotter pin for both the latch and the cap.  It worked for me.  It also saved the day when the latch broke and I need gas.  Easy to remove!
Steve_K
« Reply #6 on: January 15, 2009, 05:50:44 PM »
I've got a few of Mark's (Hondaman) kits, they look really good, but I haven't painted my tank yet, so I haven't tried them yet. Cheers, Terry. ;D
Offline Patrick
« Reply #7 on: January 15, 2009, 05:55:28 PM »
I've used two of Hondaman's kits. They work very well.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline slowjo
« Reply #8 on: January 16, 2009, 02:58:02 PM »
Thanks for the info. I'm in the process of ordering a set from hondaman. From what I read I wont be disappointed.
« Reply #9 on: January 16, 2009, 03:00:29 PM »
Me Too!
