Author Topic: 750 will 74 motor fit in 75 frame  (Read 1045 times)
Offline tramp
« on: January 16, 2009, 10:04:31 AM »
will a 74 motor fit on a 75 frame?
the 75 has disc in the rear which i consider better than drum
the motor on the 75 is a f motor but seized
plus both wheels on the 75 are good
the 74 frame has a bent rear wheel
« Last Edit: January 16, 2009, 12:00:04 PM by tramp »
1974 750k
Offline Geeto67
  • A grumpy
Re: 750 will 74 motor fit in 75 frame
« Reply #1 on: January 16, 2009, 12:45:06 PM »
74 is going to be a K frame. If your 75 has a disc in the rear it is probably an F. Yes the bikes should be a direct swap (although there is probably going to be an issue if you needed to swap internals).
a bent rear wheel is not a reason to throw the bike away. Bent other things are.
and the drum brakes on the rear generally work better than the 75-76 F rear disc.
Maintenance Matters Most
KingCustomCycles.com
« Reply #2 on: January 16, 2009, 01:51:29 PM »
To my knowledge, all 69-78 motors will fit in all 69-78 frames excluding the CB750A Hondamatic.
Offline GammaFlat
« Reply #3 on: January 16, 2009, 02:42:10 PM »
Agreed.
The only "minor" issue I'm aware of is the output shaft.  69-76 share the same "fit" for a sprocket (530 sprocket with a locking retainer that takes 2 bolts) and the 77-78 share the same (630 sprocket has a single center bolt and washer to hold on the shorter output shaft).
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
