Author Topic: Project Anti Bling - Bar Hoppin CB550  (Read 20177 times)
Offline cafeconleche
Re: Project Anti Bling - Bar Hoppin CB550
« Reply #50 on: August 15, 2009, 12:37:45 PM »
Beautiful job. looks awesome, makes me want one
Offline Flying J
« Reply #51 on: August 18, 2009, 12:10:12 PM »
How tall are you?
Offline Frankenkit
  • Industrial Strength
« Reply #52 on: August 18, 2009, 12:11:29 PM »
I was going to ask that, too.  The bike looks very short and low compared to him, even though he lengthened the frame way out.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
sauce
« Reply #53 on: August 18, 2009, 05:06:45 PM »
How tall are you?
5'10 about 200 lbs
Offline verboten1
  • Der König
« Reply #54 on: August 19, 2009, 12:17:43 PM »
do you have to use special cables for that throttle, or will it use the OEM cables?
1975 CB550F
1982 XV920
2000 KLR65085
  • Be careful you might get a
« Reply #55 on: August 19, 2009, 12:52:30 PM »
I bought one, received it and installed it without even removing the throttle cable from where it attaches to the carbs. So, yes, it works with stock cables. The next things to do is make my own kill switch and for the design I'm ideas I'm using this.
http://zero-eng.com/catalog/product_info.php/cPath/1_8/products_id/40
Using some scrap aluminum and a $5 switch found local I should be back in business in no time. ;D
Offline verboten1
  • Der König
« Reply #56 on: August 19, 2009, 03:05:34 PM »
awesome man, thanks I think I am going that route and making up my switches as needed.
Ignition will be a toggle switch, as will the kill switch, and starter will be a hidden switch somewhere, it seems to start well with the kicker even cold, so the starter switch will just be for emergency use.
I like the mount plate too!
1975 CB550F
1982 XV920
2000 KLR65085
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #57 on: August 19, 2009, 03:44:49 PM »
I love your vision. Very impressive. ;D
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Offline Bonafide
« Reply #58 on: August 19, 2009, 07:58:53 PM »
One of the few choppers I like.
Aint that more along the lines of a bobber ... ???
whatever it is .. sauce, nice job mang. That thing is too kool for skool.
sauce
« Reply #59 on: August 19, 2009, 08:21:47 PM »
So how did you wire this up with out turn signals and such? I'd love to see a diagram if you have one.. trying to lose some wires on my bike.. can't keep it started at the moment.. Ran for 101 miles then I plugged the head light in and it died 10 minutes after. Now it will never start even with the battery fully charged.
Here is what I used to wire it up.  It works great and started on the first kick.  If you are struggling with the stock wiring, just ditch it and start fresh.  If you lived near me, I could have you wired up in about 2 hours.  Once you get down to the bare bones of it, there are really only 25 wires that are needed.  Send me a PM if you run in to any problems, I would be happy to help you out.
http://www.hondachopper.com/images/simple.wiring.diagram2.jpg
sauce
« Reply #60 on: August 19, 2009, 08:22:58 PM »
Uses OEM cables :)
sauce
« Reply #61 on: August 19, 2009, 08:26:29 PM »
I wanted to keep things simple, so I am using a marine grade ignition switch that I can key the starter with and 1 toggle switch for the hi/low beam.
sauce
« Reply #62 on: August 19, 2009, 08:34:10 PM »
I think it has some elements of both.  It has the stripped down aspects of a bobber, and the raked out, stretched stance of a short chop.  Personally, I like to call it a dragster.  Meh, who cares, I am going out to ride  ;D
Offline Zaipai
    • My Home page
« Reply #63 on: August 20, 2009, 04:53:13 PM »
Wow thanks for the link. Just the sort of thing I was looking for.
Its my Avatar..
75 CB550F  |
Offline GoatBaSS
« Reply #64 on: August 21, 2009, 05:17:20 AM »
Check the headlight. Could be blown....
Leethal # 3046?
Offline wesbailey1
« Reply #65 on: May 24, 2010, 12:39:39 AM »
this bike is exactly what im going for. wow  just started chopping friday night and ive been searching for a simple wiring guide (which i found here THANK YOU ) and now im really curious how long the bottom pipe you added is before the bend and what degree bend is that ?
Offline wesbailey1
« Reply #66 on: May 24, 2010, 12:52:53 AM »
actually... that wiring link didnt work.   dannnng.
Offline cdoggy81
« Reply #67 on: May 24, 2010, 03:51:38 PM »
nice build!
Offline Zaipai
    • My Home page
« Reply #68 on: May 24, 2010, 05:29:05 PM »
The site it links to has been changed,
http://www.hondachopper.com/garage/simple_wiring_diagram/simple_wiring_diagram.html <-- One image..
http://www.hondachopper.com/garage/garage.html  <-- Some links to other diagrams..
.: Scott :.
Its my Avatar..
75 CB550F  |
