Author Topic: Question about 750 A  (Read 1043 times)
« on: January 17, 2009, 06:55:52 PM »
Does a 750 come with a tach drive?
Offline Spanner 1
Re: Question about 750 A
« Reply #1 on: January 17, 2009, 09:49:42 PM »
No...a 750A does not come with a tach. drive.
« Reply #2 on: January 17, 2009, 10:03:06 PM »
I am asking because I found a valve cover with what I thought may be a factory tach plug. When I took the plug out, I found that it has a small step that goes thru the seal, ie where the shaft went thru.
On the ones I made, the oil is kept out by an o-ring on the hole outside the seal portion. So I concluded that it was likely homemade.
But then the thought occured to me that perhaps they not only put in a plug, but may have left the drive out as well.
If this was a factory plug, then it would not fit on a bike with only the tach cable removed.
Offline Spanner 1
« Reply #3 on: January 17, 2009, 10:09:41 PM »
Hold everything!... I'm going out to look at my 750A now, back in a minute
Offline Spanner 1
« Reply #4 on: January 17, 2009, 10:18:01 PM »
I guess I , like Pres. Bush, " mis-spoke ". My '77 750A has a tach. drive 'hole' in the rocker cover plugged with an aluminum 'bung'....if there is a tach. drive gear on the camshaft, I don't know.
