Author Topic: 76 CB750f top end o rings(help needed)  (Read 3859 times)
stlal
« on: January 18, 2009, 07:29:18 PM »
Heys guys...
First off I have used the hell out of the search function so please forgive me if this has been covered.  I can't find it.
I have a 76 cb750f and I am rebuilding the top end.
I have been looking at the micro fiche and see part number 12116-300-000 (12mm pins)  8 of them
I cant locate them on the cylinder
If some body can fill me in on all of the gaskets and o rings on the top end I will appreciate it.
Thanks
So far I know I have to replace these gaskets and rings
4 discs
valve cover
cam tensioner
2 orfices
base gasket
head gasket
Thanks in advance
Offline Kevin D
  • SE Michigan
Re: 76 CB750f top end o rings(help needed)
« Reply #1 on: January 19, 2009, 05:46:44 AM »
I have used the hell out of the search function. I can't find it.
Some times I find stuff and then can't find my way back to it. :D. Search, history, you name it. But just keep looking around and you'll find plenty.
There are 6 of those sealing pucks.
Service bulletin #42 describing pins/seals from Technical Library at Main Page. Early engines don't have them.
http://sohc4.com/tiki-list_file_gallery.php?galleryId=2
Parts Resource from Forum FAQ:
http://forums.sohc4.net/index.php?topic=743.0
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
stlal
« Reply #2 on: January 19, 2009, 07:38:23 AM »
That service bulleten helps alot.
I knew there was six..not sure why I said 4
Thanks
stlal
« Reply #3 on: January 21, 2009, 07:20:16 PM »
I am having a hard time reading the micro fiche
Does anybody know/have a list of all the gaskets/orings needed from the base gasket to the rocker cover?
I have the athena gasket kit but I want to be sure every gasket and oring gets replaced.
Please  HELP!!!
Thanks
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« Reply #4 on: January 21, 2009, 07:46:23 PM »
anyone have a diagram similar to that for the orings and such for under the cam towers and in general the top of the head?
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
Offline gregimotis
  • poet laureate; SOHC4.
« Reply #5 on: January 21, 2009, 09:21:34 PM »
I did this job on my 76 cb750 f last year and took some photos and such.  will try to come up with some of that stuff.
Offline gregimotis
« Reply #6 on: January 21, 2009, 09:22:50 PM »
Here you can see some of the o-rings in position on the cylinders and also the two brass tubes on either end too aid alignment:
Offline gregimotis
« Reply #7 on: January 21, 2009, 09:26:09 PM »
And here is another view of the same thing.  The o-rings are in the realtive positions on the cardboard and one of the brass tubes is out:
Offline gregimotis
« Reply #8 on: January 21, 2009, 09:27:36 PM »
I have some photos of the top also, but will have to get them later.
Offline 78 k550
« Reply #9 on: January 21, 2009, 09:27:56 PM »
I use Britt Honda My dealer out here.
go to there parts fiche.
http://www.brittpowersports.com/
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
stlal
« Reply #10 on: January 21, 2009, 09:49:17 PM »
Ok.. so you have a total of  10 o rings?
Do you have 8 12mm knock pins  with the 8 outside o rings and the 2 dowels pins?
« Reply #11 on: January 22, 2009, 06:34:00 AM »
gregimotis if you dont mind posting those pics as well i would appreciate it.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
Offline gregimotis
« Reply #13 on: January 22, 2009, 10:07:55 AM »
Gamma's pic and mine are essentially the same for the top end.  You see the six pucks and the four little o-rings which all go under the cam towers, and the six or so brass 'tube thingy's which help line everything up.
And yes, ten underneath : two o-rings, eight o-ring like inserts, and the brass tube-thingy's
Midnight, the two center 0-rings which go between the cylinder and head look like the o-rings you have left over in your other thread... maybe they belong there?
« Reply #14 on: January 22, 2009, 10:18:27 AM »
they are too small and i have those O-rings in there. im not sure where they go. are there o-rings for the cam chain tensioner?
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline gregimotis
« Reply #15 on: January 22, 2009, 11:07:12 AM »
Negative, just the gasket.  Now that I think about it, I seem to recall having a couple small o-rings left over as well... I'll check my 'extra parts' cup tonight and see what I find in there.
« Reply #16 on: January 22, 2009, 12:33:23 PM »
thanks
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline gregimotis
« Reply #17 on: January 22, 2009, 09:20:10 PM »
I don't have the o-rings to prove it but I'm pretty sure I had two left over as well.
They were a little larger than those four which go under the cam towers.  At the time I hadn't removed the jugs, so I decided they probably belonged down there somewhere.  1500 miles later and no troubles.
I got my kit from Cycle-X.  You could call your supplier and ask about it, maybe they fit a different year or something.
Sorry, I can't answer definitively.
« Reply #18 on: January 23, 2009, 04:51:15 AM »
mine came from cycle-x as well. how has your kit been holding up?
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline gregimotis
« Reply #19 on: January 23, 2009, 09:32:01 AM »
Here's my thread - you'll notice most of the trouble I had came from trying to be cheap and not taking good advice.
http://forums.sohc4.net/index.php?topic=35937.0
my kit was allright, although in the end I purchased base, head, and valve cover gaskets from Honda.  Partly because the valve cover gasket did not fit - although I hear this is not typical of kits from Cycle-X.
stlal
« Reply #20 on: January 24, 2009, 12:26:08 PM »
Here is my gaset kit.
Can anybody identify all these orings?  I labeled them by line for easy explanation
Also there is a pic of my cylinder...I think is came from a K model since there is no way to install the 8 knock pins...I am assuming I just place the orings along with the head gasket?
Any help will be very much apreciated.
Thanks
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #21 on: January 24, 2009, 01:51:15 PM »
Hot Topic...I just posted the same question this morning. My 74 750k4 does not have the 12mm pins and seals, just the 2 dowels, 2 o-rings and head gasket. Then on the top, the pucks and 4 o-rings under the cam towers...
http://forums.sohc4.net/index.php?topic=45701.0
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
stlal
« Reply #22 on: January 24, 2009, 06:04:26 PM »
Is it possible I have  K model jugs?  I know I do have K pistons
I am sooo confused
stlal
« Reply #23 on: January 24, 2009, 06:14:47 PM »
Ok...after comparing my cylinders to yours it seems mine is something different that a 76 F model, My cylinder head is marked F and the engine number is F.
Any ideas?
It is bored 1mm over and everything else seems to be in good shape.
Offline Kevin D
  • SE Michigan
« Reply #24 on: January 24, 2009, 09:30:25 PM »
Yep, your cyl doesn't have the cutouts for the return oil seals (#3 in your pic).
As for those other o-rings, you should measure them and compare to parts fiche. Did you get a list with your gasket kit? Did you get a complete kit or a top end kit? Looks like you might have stuff for the bottom end too.
Just guessin' now - dont take this to the bank. Check the measurements to be sure.
#4 top end oil feed (2 studs at center rear of cyl).
#6 under cam towers
#7 big dowel between cases or neutral switch
#8 oil pump and hoses
#10 oil cap above points
#11 trans oil feed passage near shift linkage
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
