Author Topic: Replacing Cam Chain During a Top-End Rebuild CB350F  (Read 2270 times)
Offline OakBehringer
« on: January 19, 2009, 11:05:27 PM »
Is the cam chain something that can/should be replaced during a top-end rebuild?
Thanks,
Adam
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline Trevor from Warragul
Re: Replacing Cam Chain During a Top-End Rebuild CB350F
« Reply #1 on: January 20, 2009, 02:31:55 AM »
Yep.  Get a new camchain & three soft links from David Silver Spares (two extra links to practise rivetting with).  Get a chain breaking/rivetting tool from Motion Pro (when I did mine I took up some of the sideways freeplay in the rivetting tool with some teflon tape).  Break the old chain, attach the new chain to it with string, and pull the new one through.  Untie the old chain, then practise rivetting on it.  When you think the results are good, rivet the new chain together.  Piece of cake!
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
« Reply #2 on: January 20, 2009, 12:37:07 PM »
Awesome, thanks!
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline LoopsAndLogic
  • Dang IT!!!
« Reply #3 on: January 20, 2009, 04:42:41 PM »
Make sure that after 100miles you re-tighten your chain....It'll stretch just like a normal
drive chain.
But yeah, I guess DSS is the only one to have soft rivet links....bummer.
Hey, post a video of your results...I have a few 400f's that need there cam chains replaced
because of there widely known problem.
Cheers
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
« Reply #4 on: January 21, 2009, 08:02:27 AM »
Three questions :)
Why is that a bummer?
This is from my bike-chain "expertise"... sorry about the dumb question...
In regards to "breaking the chain" - I assume this is using a chain tool like this...
http://www.fullcycles.com/images/park-ct-5-chain-tool.jpg
...to remove a rivit?
Honda OEM replacement chain is best, right?
Thanks,
Adam
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
  • Dang IT!!!
« Reply #5 on: January 21, 2009, 09:37:37 AM »
Bummer in a sense that you can only find these soft rivets for these really small chains at DSS. ;D ;D ;D ;D ;D
And Yes, the Honda OEM cam chain is best because it doesn't have a weak point...
There's a lot of talk about this, but I know many that didn't want to tear down the whole
engine just to replace the chain and there results were just as good as OEM performance and durability.
I think that's the chain breaker.... ??? ???
Sorry about that...I really don't know...
Cheers
LL
My rides:
Past Rides:
« Reply #6 on: January 21, 2009, 10:56:59 AM »
the tool you posted will break the chain , but not press it back together , you want this one
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=28350&store=Main&catId=&productId=p28350&leafCatId=&mmyId=
« Reply #7 on: January 22, 2009, 02:21:25 AM »
That's the tool for the job.  However, on my first (practise) attempt at rivetting, the tool kept slipping off the soft link's dead centre, due to sideways movement in the tool.  The result was a lopsided mushroom on the end of the soft link.  I solved this by wrapping some teflon tape around the rivetter.  This took out the sideways movement & resulted in a perfectly centred mushrooming of the soft link.  I hope this makes sense..
1971 Kawasaki H1A
1972 Honda CB350F
1978 Honda CBX
« Reply #8 on: January 22, 2009, 08:20:44 AM »
That chain tool is $95! Is there a cheaper alternative that will give good results?
Any of these?
http://www.sportsmansguide.com/net/cb/cb.aspx?a=423032&kwtid=274648
http://www.sportingforless.com/Cam-chain-breaker-p/t34.htm
Even the second, at $50, is kinda pricey. I wonder if I'd be better off bringing my case & the new chain to the mechanic who has my head when I pick it up.
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
« Reply #9 on: January 22, 2009, 10:23:06 AM »
that second one looks to be the same as the one i posted, only made by a different company
(and alot more affordable)        if you want the job done right,    you need the right tool (a sad reality somtimes i know)
 and if you do end up doing this yourself make sure you stuff some rags in the openings in the motor , you don'y want to drop a rivit in your motor ,   go ahead ask me how i know
CU2151
« Reply #10 on: January 22, 2009, 04:25:45 PM »
I've been there.  A really useful tip!
I managed to snag a motion pro one off of ebay for cheap about a year back.  Might be something to check out.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #11 on: January 22, 2009, 04:54:44 PM »
That's my plan.  Get an OEM chain ('77 550k) and a "soft link" from a CB500T (DK219 chain size) then take them and my engine bottom to a local shop.  The owner has been riveting cam chains longer then I've been alive!  Great guy to talk to.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
