Author Topic: cb550 valve adjustment  (Read 10477 times)
turk
« on: January 22, 2009, 12:11:50 PM »
I am new to working on motorcycles,so I'll be asking some questions to learn more about my 1976 cb550.Everyone here seems more than willing to share their knowledge.If it weren't for this site i wouldn't even dream of trying this.Thank-you!! My cb550 hes been sitting for 8 years.So i wanted to check the valves and timing first.My Haynes  manual says .002 on the intake,.003 on the exhaust. Are these specs. good for the "real world" Any other advise is more than welcome. Thanks Turk
Offline OldSchool_IsCool
  • Really feeling like an
Re: cb550 valve adjustment
« Reply #1 on: January 22, 2009, 03:22:12 PM »
yes, those specs are right on.  Only rarely has real world experience shown where Honda engineers could have done a better job.  By the way, get yourself one of these
http://www.motionpro.com/motorcycle/tools/view/tappet_feeler_gauges/
to make the measurement easier.  Your local MC shop prolly caries them or order online.  You might also want to get a .004 feeler.  You'll see why in a moment.
To adjust your intake tappet,
- rotate and position your crank as described in your Haynes manual
- Does the .002 slip between the tappet and the valve?
-- no  - your adjustment is too tight.
-------- Loosen the lock nut and adjust the set screw outward.
-------- repeat this procedure until you are right on
-- yes - does the .003 fit?
-------- no Your adjustment is right on!
-------- yes
---------- your adjustment is too loose.
---------- loosen the lock nut and adjust the set screw inward
---------- repeat this procedure until you are right on
For your exhaust tappet, do the same procedure except use your .003 and .004 feelers
« Last Edit: January 22, 2009, 03:24:16 PM by OldSchool_IsCool »
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline scunny
  • don't call me expert
« Reply #2 on: January 22, 2009, 03:36:06 PM »
thats how I do mine...go-no go
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
turk
« Reply #3 on: January 22, 2009, 04:08:09 PM »
Thanks,I had measurements all over the place. intake  1 .004   2 .005    3 .005       4 .003
        exhaust 1 .005   2 .004    3 .003       4 .006
Being new to this i want to make sure I'm doing this right.It is a hard to use a regular feeler gauge.
the one you use will sure be a lot easier and i like that go/no go tip!
Is the Clymer manual any good? I have the Haynes and it seems to leave out some steps.                               Thanks  Turk
Offline 1timduke
  • '75 CB550
« Reply #4 on: January 22, 2009, 05:02:55 PM »
I dunno about the Clymer, Turk.   I've got the Haynes and it's ok, but tends to gloss over really important stuff occasionally.   It used to be a staple in my bathroom but I rarely use it it now, this site has about all the tips and tricks you'll need.   And no, my laptop logged on to this website is not my new bathroom 'book'. ;D ;D ;D
If you're searching for something in particular, don't forget to check the tips and tricks section, that's got some useful stuff too.
Sitting for 8 years :o   Post some pics when you get the chance, 'before' pictures are always nice ;D
-Tim
The only thing I miss about the South is Waffle House!
Offline Lars
« Reply #5 on: January 23, 2009, 05:05:54 AM »
I find the Clymer better than Haynes. Sometimes it is a bit hard to get the feeler placed, usually I loosen up the lock nut and start from scratch.
You will find some advice on my website:
http://www.hondahobby.no/website.aspx?displayid=1754
Lars
...if you got the ability to act...
