Author Topic: anyone have a bike lift/jack?  (Read 4751 times)
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
Re: anyone have a bike lift/jack?
« Reply #1 on: January 23, 2009, 09:45:13 AM »
check this out... anyone had any experience with these type lift/jack's? anyone heard anything about 'em?
thanks
http://cgi.ebay.com/ebaymotors/BRAND-NEW-1500-LB-MOTORCYCLE-STREET-ATV-QUAD-JACK-LIFT_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1171Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem220347224745QQitemZ220347224745QQptZMotorsQ5fAutomotiveQ5fTools
That style is widely available. Works good for cruisers/Harleys as their pipes hang off the side. Ours go underneath and make those types of lifts inconvenient.
okie
« Reply #2 on: January 23, 2009, 10:52:39 AM »
I will sell you mine for $40.
    • My Album
« Reply #3 on: January 23, 2009, 10:56:02 AM »
is it the same style? what kind of luck have you had with it? or is that why you want to sell it?
Offline Really?
« Reply #4 on: January 23, 2009, 11:02:22 AM »
I do not use them, to skeery for me.  Will always feel the bike will fall off.  And, 2nd gen ventures may use them but they mod mounts to make them work to go around the pipes.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline mark
« Reply #5 on: January 23, 2009, 11:04:56 AM »
save up your nickels and get one of these.
F you mark...... F you.
    • My Album
« Reply #6 on: January 23, 2009, 11:05:52 AM »
dont have an extra $700 to spend on it
Offline bunghole
« Reply #7 on: January 23, 2009, 11:43:18 AM »
I've thought about something like this as well.  How do you remove the wheels?  What if you need to pull both wheels?
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline mmtsquid
« Reply #8 on: January 23, 2009, 11:50:39 AM »
I bought one for my father in law from Sears (nearly identical in design), and it works great!
It cam with ratchet straps to make the bike more secure.
77 CB550K4
eldar
« Reply #9 on: January 23, 2009, 11:51:31 AM »
A lift is good to raise the bike over all but a jack is best for removing the wheels. As it is only a little pain, just remove the exhaust first.
Offline Really?
« Reply #10 on: January 23, 2009, 12:13:30 PM »
Nope, I will not do it.
Wheels can be removed easily with the centerstand for the rear and centerstand/floor jack for the front.  I do this on my VR as well.
I love my low cost floor jack.
Offline Really?
« Reply #11 on: January 23, 2009, 12:14:59 PM »
There are more expensive ones where the floor drops out.
eldar
« Reply #12 on: January 23, 2009, 12:19:51 PM »
I would remove the exhaust. Why not? It gets in the way and it protects it as well while you are working on things. Besides, how often would you really have to remove it? Maybe once a year if that? Most people would not even have to do it that often, after all, you do not need to remove the wheels every year. besides, exhaust seals are cheap. Cheaper than an exhaust.
Offline Really?
« Reply #13 on: January 23, 2009, 12:36:40 PM »
That would be like pulling the engine to take a spark plug out.
NEway, there are two things, well many things, at this link that I am interestined in.  The part that fits this thread is low cost and something I would like to make work on the k5.
You can remove the wheels too.  I want to loose the centerstand on the k5, tooo big and bike is getting low.
http://www.discountramps.com/motorcycle-stands.htm
eldar
« Reply #14 on: January 23, 2009, 01:52:08 PM »
Not at all. When doing a lot of work, you have to do it around the exhaust. Maybe not an issue with 1 pipe but 4 take a lot of room. Many times have I wanted to take them off. Makes getting to the swangarm easier and centerstand and a lot of other things easier. I dont expect you to do it but imo, it makes things easier.
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #15 on: January 23, 2009, 02:32:17 PM »
I have a lift (plat form style) and a bike jack. I havent used my bike jack since I bought the lift.
 Check Sears for their bike jack. When you factor in shipping with the Ebay one, it may be cheaper to get the Sears unit.
   My lift has a removable drop out to remove the rear wheel. When I want to remove the front wheel I used some straps to hold down the rear(and pull the front up).
   My back has loved the lift since I got it. No more crawling on the floor to do what ever. From what I understand, Harbor Freight has lifts at a very good price (if you  have the $ and room).
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
eldar
« Reply #16 on: January 23, 2009, 02:38:17 PM »
Yeah lifts do take up a lot of space. I suppose if you get a durable one, you can maybe just park on it then.
Offline mystic_1
  • 1970 CB750K
« Reply #17 on: January 23, 2009, 07:20:09 PM »
Removing the exhaust takes, what, 15 minutes?  If you're pulling the rear wheel, you need to drop the exhaust anyway, or at least it makes the job much easier.
mystic_1
- John Augustus Shedd
« Reply #18 on: January 23, 2009, 08:32:08 PM »
That's how I do my wheels also. Not to keen on jacking if can be done otherwise. For the front, I use centerstand and a tie hanging from the ceiling attached to the handlebar/front fork etc.
Also I have one of these. http://www.baxleycompanies.com/Sportchock.html
Quite nice well built. Holds bike firmly upright by the front wheel. Will also hold by back wheel, but a little assistance needed backing it into place. Great on a track day if you have removed your stands. Can be hung on wall when not in use. Others of similar design, cheaper but not as sturdy.
Lifts are great but do commit some floor space I don't have.
fuzzybutt
« Reply #19 on: January 23, 2009, 08:58:06 PM »
i have this one here. i use a scissors jack to lift front or rear to do wheels.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91764
okie
« Reply #20 on: January 23, 2009, 09:09:34 PM »
The reason I don't use my MC jack is it is more convenient to use my Sky Hook. ;D ;D ;D  And the Sky Hook doesn't take up any floor space when it isn't in use.
« Reply #21 on: January 23, 2009, 09:14:51 PM »
I have had the Sears Model for years. I have stock pipes and if you center the jack under the bike properly you just lift it up. No issue with the pipes. Had it on the jack a whole winter once.
« Reply #22 on: January 23, 2009, 09:31:21 PM »
I use the ratchet type tie-downs from the ceiling to lift with, but they are limited obviously. Now an electric motor...I've got to look into that! Sweet!  Is Sky Hook the brand name?
That floor makes me dizzy. ;)
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #23 on: January 25, 2009, 03:51:03 PM »
Aside from the fact that it's Chinese and may not be American quality,
THIS lift is on sale for $399.
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
Offline BIKE
« Reply #24 on: January 26, 2009, 08:58:35 AM »
Looks like the Harbor Freight hoist.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=2954
1975 CB750 K5
1977 CB750A
