Author Topic: any problems or issues with the t500?  (Read 9157 times)
fuzzybutt
« on: January 24, 2009, 07:04:06 PM »
i have a chance to get a suzuki t500, a 72. all i have to do is drive to ohio to get it. are these worth a 16 hour round trip? it needs a new barrel and head. other wise complete
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: any problems or issues with the t500?
« Reply #1 on: January 24, 2009, 07:25:28 PM »
I just looked up some pics of the bike, it looks like a pretty sweet model to have in the collection Fuzzy. I didn't find any info on that model but being an aircooled 2 stroke I would be looking at the engine......which you say it needs a barrel anyway.
I bet Bill might have a better idea about this one..
 Matt.
Gallery at:
Offline mark
« Reply #2 on: January 24, 2009, 07:55:17 PM »
I had a T350 way back when and it was a blast. dunno about parts nowadays but there aint much to one anyway.
a quick look at flebay shows barrels, heads, NOS piston sets, and gaskets - now all ya need is bucks.
 ;D
F you mark...... F you.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #3 on: January 25, 2009, 09:31:14 AM »
       Fuzzy, I've never had one, but I've also never heard a bad thing about them myself. I think there's a pretty good following of them, although no where near what the Hondas have (as a rule). Personally, I think it'd be a good addition too. Here's some stuff on it, in case you hadn't already checked it out.
      "1972 Suzuki year code: J
In 1972 the T500J was gaudier than ever with large chrome plastic sidecover ornaments. This model was probably the most attractive of all with Candy Vedoro Green or Pearl Orange petrol tanks. A noticeable change for this year was the adoption of a larger tail-light lens which would remain standard on the GT range as well.
Suzuki T500L T-500 LT 500 J 1972
Overall Length: 2,195 mm (86.4 in)
Overall Width: 870 mm (34.3 in)
Overall Height: 1,125 mm (44.3 in)
Wheelbase: 1,435 mm (56.5 in)
Weight: 187 kg (412 lbs)
Engine type: Air-cooled 492 cc inline-2, 2-stroke. 47 hp/ 7,000 rpm, 5.3 kg-m/ 6,000 rpm."
         They built the T500 from 68'-75' and here's a link to the history, if you'd like to check it over. I would think that there would be several, if not most of the year model parts could be used on any one model. That would just have to be checked out p/n by p/n on a place like crotchrocket.com. Don't know if any of that helps or not, hope so. :) Are there any photos to be had, that you can check out?
       Whoops, I forgot to put in the link. :-[ Sorry bout that.
        http://www.suzukicycles.org/T-series/T500_models.shtml
« Last Edit: January 25, 2009, 09:34:10 AM by bill440cars »
Member # 1969
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #4 on: January 25, 2009, 12:20:10 PM »
Have been looking for a T500 since the x6 is done. Was the hot setup in 68-69 before the 750-4. Parts are available and cheaper that other Suzuki 2-strokes. Seem to have a growing following. I'm in Ohio if you if you decide against it!  ;D
Fonda Honda
Offline Geeto67
  • A grumpy
« Reply #5 on: January 26, 2009, 12:36:03 PM »
the only real problem with the t500s is that early ones are known to have 4th/5th gear failures. The T500 engine (up to 1972) holds 1200ccs of gear oil and this left 4th and 5th aprtially exposed to air. Over time they would loose their hardening and fail. Suzuki changed the engine case capacity to 1400ccs in 1973 and this fixed the issue, they also issued a manditory service fix for earlier bikes but it is hit or miss if this was actually done on your bike. Most guys use a beer can to do the mod but you can buy the part to make the engine case hold extra oil also (it is just a matter of filling a small barrier inside the case). YOu have to crack the case to do the mod but these bikes are stone simple to work on. Really it makes working on a SOHC 750 feel like working on the space shuttle.
Like any old two stroke if it has been sitting then you are also hit or miss on the engine seals. If it were me I would split the cases and have the crank rebuilt and check if the case was modded (and mod it if it needs to be).
Once in good shape they are excellent riding bikes. Not hooligan like the kawasaki h bikes, just a smooth two stroker with good handling. I own two '71s and just traded my 1970 for a kz900. One of mine has an ex AHRMA race motor, wiseco forged pistons, and decked heads and screams when you come on the pipe, the other was just a nice commuter until 5th gear failed and now is just a nice pile of parts in the garage.
Maintenance Matters Most
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #6 on: January 26, 2009, 01:05:44 PM »
I used to want one of those as a restoration project. They can be very cool. Then I had a chance to ride a restored one. That ended my desire to own one.
The vibration coming up through the handle bars even with the proper rubber mounts is simply unbearable.
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
Offline voxonda
« Reply #7 on: January 26, 2009, 01:24:43 PM »
Hi,
I owned a 500 Titan. Had a lot of fun with it. Was my first bike back in the early seventies.
Hope my wife won't see this pic, this is one of my earlier girlfriends!  ;D ;D Pipe was a 2 into1 Reimo, did not too much good to the bike but sounded awesome. Later changed into seperate chambers and some Daytona tricks.
Cheers, Rob
« Last Edit: January 26, 2009, 01:26:29 PM by voxonda »
Offline Geeto67
  • A grumpy
« Reply #8 on: January 26, 2009, 02:50:12 PM »
there is a pretty simple mod you can do to put GT750 silentblocks in the engine mounts, but the engines are rubber mounted already (it is solid rubber where as the buffalo silent block is corrigated). They do vibrate though, not much more than any other 2 smoke but some people can hack it and some can't. The GT750 mounts make a big difference.
fuzzybutt
« Reply #9 on: January 27, 2009, 09:40:54 PM »
oh well the deal fell through when i refused to buy a gun and bring it to him.
« Reply #10 on: January 27, 2009, 10:55:03 PM »
WTF..... ???
fuzzybutt
« Reply #11 on: January 28, 2009, 01:21:55 AM »
the guy i was going to get the motorcycle from has a felony on his record. cant buy guns with that. i have a permit to carry and i dont want to risk that permit or my right to bear arms.
Offline bill440cars
« Reply #12 on: January 28, 2009, 07:51:56 AM »
      Understood fuzzy.   Too bad, but there'll be another deal that will be more on the up and up. ;) Good thing that you found out about the felony. ;)
Member # 1969
fuzzybutt
« Reply #13 on: January 28, 2009, 06:07:13 PM »
i have a line on an h2 with loads of spare parts down in orlando. trying to figure out where the 500 is going to come from now, i may sell my tokarev military pistol.
fuzzybutt
« Reply #14 on: February 04, 2009, 02:06:26 PM »
my buddy in ohio called me last night and told me if i drove up i could have the thing after all. all it needs are cylinder and a head. i'm thinking i'll dismantle it and put the parts in the back of the ol' saturn
« Last Edit: February 04, 2009, 02:08:10 PM by fuzzybutt »
Offline crazypj
  • I'm brill, me
« Reply #15 on: February 05, 2009, 06:31:39 AM »
If you beat on them they lose second gear. The later GT500 didn't have the problem for some reason (don't know if it was modified?)
I had a GT500 but don't remember owning it (my brother keeps telling me I sold it to him though?)
The heads crack if spark plugs are overtightened (from plug hole to one of holding down studs, usually front 'outside) common as people don't normally use torque wrench on spark plugs. swing arm bearing wear out, but that's 'normal'  ;)
PJ
fuzzybutt
« Reply #16 on: February 05, 2009, 12:19:33 PM »
what kind of hopups can i do on this bike? i've never owned a 2 stroke before. it already has expansion chambers from, i think he said something like gemco maybe? i think the gearboxes up to 72 had alot less oil capacity, as i understand it it's easy enough to mod the earlier cases for the extra capacity. as it's been sitting a while i'm going to assume that seals will have to be done. from what i learned about 2 strokers at AMI, the labarynth (sp?) seal is the most important one. wheres a good place to get parts for these? it also has a dunstall tail and 1/4 fairing.
Offline crazypj
  • I'm brill, me
« Reply #17 on: February 06, 2009, 06:37:17 AM »
There should be quite a lot of information available, depends how deep your pockets are
Bike was raced for a number of years (probably still is in pre72? vintage)
 You can get plenty of power to get you into trouble, port it anywhere from (aircooled) RM250 spec to full roadrace spec (RM had a broader powerband)
 I have a friend in Britain who may still have factory road race specs.
 If so, I'll PM you about it
PJ
fuzzybutt
« Reply #18 on: February 06, 2009, 11:09:39 AM »
are there any decent forums dedicated to these motorcycles? anything close to the calibre of this one even?  :D
« Reply #19 on: February 06, 2009, 04:59:58 PM »
Google suzuki 500 fanatics and it will lead to gads of hop-up ideas.
Offline Trevor from Warragul
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
fuzzybutt
« Reply #21 on: February 09, 2009, 08:18:47 AM »
thanks a bunch for the suggestions folks. i joined that forum you sent me to morini
« Reply #22 on: February 09, 2009, 11:16:28 PM »
It's a great forum!  I have a Kawasaki H1A Mach III 500cc triple.  You'll either LOVE the T500 or HATE it.  I LOVE 2 strokes.  They're just so mental!  I wouldn't want to have it as my only bike, but it's great for the occasional blast (reminds me of being 20 years old & irresponsible).
Trevor
1971 Kawasaki H1A
1972 Honda CB350F
1978 Honda CBX
fuzzybutt
« Reply #23 on: February 19, 2009, 01:50:28 PM »
well in a few short hours i leave for ohio to get my suzuki. getting more and more excited.
damn i thought it was friday, not thursday. i leave around 4 am saturday. getting a car load of sohc 750 parts too!
« Last Edit: February 19, 2009, 04:45:51 PM by fuzzybutt »
Offline hoodellyhoo
  • CB350F
« Reply #24 on: February 19, 2009, 05:02:39 PM »
Good Luck! Remember, we love pics ;D
