Author Topic: To use or not to use  (Read 1603 times)
Hondaboy
« on: January 25, 2009, 02:33:46 PM »
   I am getting ready to put my 75 550 motor back together. I have searched for this with no luck. Do I need to use some sort of permatex on the cylinder gasket, or install dry? Thanks
Offline Alan F.
Re: To use or not to use
« Reply #1 on: January 25, 2009, 02:43:45 PM »
do you mean the base gasket between the engine cases and jugs? Or the head gasket between jugs and head?  I used copper gasket spray on my head gasket due to numerous recommendations.
Hondaboy
« Reply #2 on: January 25, 2009, 05:03:27 PM »
Between the case and the cylinders
Offline Alan F.
« Reply #3 on: January 25, 2009, 07:02:28 PM »
No, I didn't use anything.  That was the concensus when I searched.  Mine's a 750K3 BTW.
Hondaboy
« Reply #4 on: January 26, 2009, 11:21:44 AM »
Thanks for the help
KingCustomCycles.com
« Reply #5 on: January 26, 2009, 11:23:17 AM »
A thin coat of Indian Head gasket compound from NAPA.
Hondaboy
« Reply #6 on: January 28, 2009, 07:36:09 AM »
Was hoping to get some more replies, I know alot of you have gone this far. What did you use? Thanks
« Reply #7 on: January 28, 2009, 07:40:18 AM »
Clean grease on the base gasket to soften the paper NOTHING on the head gasket except mirror finish metal surfaces
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #8 on: January 28, 2009, 08:58:23 AM »
Grease on the base gasket seems to help soften it. When you torque down the head studs that gasket will compress, conforming to any minuscule irregularities. If there's any oil seepage after doing this, look for other issues.
I've also used a very thin coat of Gasket Eliminator (made by Loc-tite I think) without problems, it is made to seal small gaps (up to .015") but be careful around your oil supply holes, let the O rings do their job. I coat all cover gaskets with this stuff - it does eliminate oil leaks.
DON'T USE any product like Yamabond! I saw saw the aftermath of this once, the guy ended up with broken fins trying to get the block off the case, and his covers were stuck on so hard he had to hammer them off.
I have used copper coat on head gaskets without issues, head removal and clean up was easier than a dry installation.
And if you don't already know this, I would strongly advise against using any kind of power-driven Scotch brite abrasive wheel to remove or clean up any old gasket material from aluminum. My buddie's machine shop does a good business resurfacing aluminum heads that won't seal after a Do-It-Yourselfer gets done with his Dotco and 2" discs...
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline WFO
  • Will work for powerbands
« Reply #9 on: January 28, 2009, 03:09:20 PM »
[/b]
Just curious why scotch brite disks would mess up the surface?
82 cb650 sc nighthawk - 78 kz 650 b
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
« Reply #10 on: January 28, 2009, 04:16:51 PM »
The discs come in different grits and most of them can be very aggressive when used improperly. Most vehicle makers have instructed technicians not to use them, especially on aluminum. As Nitro has said, many heads have been damaged, some beyond repair, using the discs. I have witnessed main bearing failure shortly after a valve job was performed,due to the grit getting into the oil pan. Best not to use them if you can avoid it.
.........Paul
