Author Topic: Seat Swap  (Read 2795 times)
BritishRacingGreen
Seat Swap
« on: January 26, 2009, 05:20:40 AM »
I'm new here, so sorry if this has been asked a million times...
I have a 1978 CB750K. Will the flatter style seat from a 1976 model fit on my '78, or do they hinge on opposite sides?
Thanks.
Offline Jay B
Re: Seat Swap
« Reply #1 on: January 26, 2009, 05:31:26 AM »
There were major changes between the 77-78 750's and 550's and the 76 and older bikes. The 76 seat will be too long by about 1-1/2" I beleive. Don't know about the hinge though.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
BritishRacingGreen
Re: Seat Swap
« Reply #2 on: January 26, 2009, 08:41:42 AM »
Thanks for the info.
Is there and aftermarket supplier who offers different styles of seats for these bikes?
Offline goon 1492
  • Sucka Repellant
Re: Seat Swap
« Reply #3 on: January 26, 2009, 09:17:28 AM »
My 750k6 hinges on the right side
BritishRacingGreen
Re: Seat Swap
« Reply #4 on: January 26, 2009, 12:49:08 PM »
That scraps the swap idea, in that case. Thanks for the info.
I like the cleaner look of the flat seat on the '76, much more than I like the slightly stepped seat on my '78. But there must be an aftermarket supplier who offers a range of styles for each year of these bikes, no?
« Last Edit: January 26, 2009, 12:53:57 PM by BritishRacingGreen »
Offline Jakoba
  • I'm far from a CB750
Re: Seat Swap
« Reply #5 on: January 26, 2009, 04:58:28 PM »
Hey BRG ...is that Mossy's old 78? ??? ???
Jako
Jako
Member #4500
"See the ditch, see the ditch, in the ditch"
Offline PxTx
  • See sig for possible trade?
  • Subs of Philly
Re: Seat Swap
« Reply #6 on: January 26, 2009, 05:39:08 PM »
What does the underside of the seat look like?  I kinda have the K8 look with the flat seat here:
BritishRacingGreen
Re: Seat Swap
« Reply #7 on: January 27, 2009, 06:33:10 AM »
Yep!
 ;D
It looks to me like the step is in the foam only, and not in the pan.
Although Mossy will probably send a hitman out after me, if I swap out the original and pristine '78 stock seat. That's why I'd like to keep it, and just find an aftermarket soruce for a flatter seat.
« Last Edit: January 27, 2009, 06:34:57 AM by BritishRacingGreen »
Offline Maxacceleration
Re: Seat Swap
« Reply #8 on: January 27, 2009, 07:02:19 AM »
Just throw dual disc's on the front. Your bike is fine!
Olden is Golden
CR550F RD400 KZ550 KH500
BritishRacingGreen
Re: Seat Swap
« Reply #9 on: January 27, 2009, 07:52:18 AM »
Your bike is fine!
Yeah, you're probably right.
And the seat that's on her will probably be more comfortable, anyhow.
Offline Jakoba
Re: Seat Swap
« Reply #10 on: January 27, 2009, 08:28:45 AM »
BRG, you are better of finding an old 77-78 (only seats that fit that bike plug&play) and send it to an automotive upholster to shave the foam and reskin, like PXTX did. I know one in Seal Cove if you are interested, he just redid this one for my father-in-law's (1981 CB750 DOHC).
Having said that I like the two up style,  helps me from falling off on launch !! ;D ;D
PS: I was the guy who could not deliver your bike on saturday night due to a previous engagement...sorry about that. Long as you got her...that's the main thing.
cheers
Jako
Jako
Member #4500
Offline Geeto67
  • A grumpy
Re: Seat Swap
« Reply #11 on: January 27, 2009, 08:40:34 AM »
there has to be a million post about this in the archive...really...search function
69-76 and 77-78 hinge on opposite sides. I have a 75K where both mounts have been welded but you could use a bolt on style mount like the F's used if you really really wanted to pull it off without welding. You could also use bolt on stainless hinges in the pan to change sides, I think classiccyclecity (i htink that it the name, the guy here who makes the guilari seats) has the hinges in stainless.
overall the 76 seat is smaller than the 77-78 but the mounts have it further forward to accomidate the shorter 69-76 tank, were you make your own mounts you could relocate the seat to fit the tank, but in the stock position the seat will be too far forward.
the cheapest and easiest option would probably be to shave the seat foam flat and recover it. YOu could have a shop do it or try your hand at it yourself.
Maintenance Matters Most
BritishRacingGreen
Re: Seat Swap
« Reply #12 on: January 27, 2009, 08:53:26 AM »
No sweat, Jako. I felt better about getting one of my buddies to help transport the bike, anyhow.
Geeto...
Thanks for your information and input.
Offline Mossy21
  • It takes "Time" to be a Classic..........
Re: Seat Swap
« Reply #13 on: February 03, 2009, 02:36:47 PM »
BRG,  Step back....Step away for the seat.  :'(    I know where you live. LOL
If I can't see the Engine I can't see the point.......
BritishRacingGreen
Re: Seat Swap
« Reply #14 on: February 04, 2009, 06:19:57 AM »
BRG,  Step back....Step away for the seat.      I know where you live. LOL
I wondered how long it would take you to figure out that I was threatening to mess with the seat.
 ;D
Offline j-conn
  • Federico Fabrizi
Re: Seat Swap
« Reply #15 on: February 04, 2009, 07:08:28 AM »
i agree. i wouldnt touch the seat. dual disc may be good tho.
1976 CB550
Member #7772
BritishRacingGreen
Re: Seat Swap
« Reply #16 on: February 04, 2009, 08:24:15 AM »
Yeah, Mossy installed a braided steel line, which is nice, but dual discs would be good.
My next mod, I'm thinkin.
