Author Topic: Engine braking vs. Brakes  (Read 4308 times)
Offline pmpski_1
  • Beast V and Beast I
    • My CB550 related blog on MSN Spaces
« on: October 05, 2005, 01:05:29 AM »
I have a habit of using 2nd gear to cruise through neighborhood streets, allowing the engine to slow me down at intersections. I don't use the brakes as much this way. I also do the same thing going down steep hills.
I'm a new rider. Is this a bad habit that I should "break" or is this ok for old bikes?
Beast   I: 1974 CB550K
Beast IV: 1976 Chevy Blazer
Beast  V: 2003 Buell XB9S
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
Re: Engine braking vs. Brakes
« Reply #1 on: October 05, 2005, 02:14:46 AM »
I use engine braking all the time, it's smoother and unsettles the suspension less. I did a track course once where we spent half the morning riding round without changing gear or touching the brakes, it's a good excercise for throttle control and encourages you to carry more corner speed. The brakes can be used to provide the extra braking required over and above engine braking,( sitting up on a sports bike can also be used as a bit of airbrake ). A good read on bike control for both track and road is Keith Code's Twist of the Wrist, he's the guy who set up the California Superbike School.
In the UK anything over 40 years old only needs insurance and Fuel.
Offline Raul CB750K1
« Reply #2 on: October 05, 2005, 03:42:50 AM »
Also, while riding on neighbourhood streets it's good to have the bike a little revved, so you have plenty of power to take off in case you need, as in a crossing or a dog attack.
Raul
Offline hymodyne
« Reply #3 on: October 05, 2005, 04:53:47 AM »
I'm a cb 500 rider who is wondering if this type of speed control is in any way damaging to the clutch.
hym
mkarcz
« Reply #4 on: October 05, 2005, 05:12:29 AM »
I am also wondering the "how?" of down shifting.  Should you give some gas, do you need to use the clutch or just click down? I have been using the clutch and gas sometimes, and sometimes not, depending on the urgency.
mark
Offline Paul
« Reply #5 on: October 05, 2005, 06:39:08 AM »
I was told once - "You are not a rally driver, do not use the engine to slow down, you do not have a crew to change the gearbox and clutch. Engine....GO, brakes....Stop."
When changing down one should have the bike at the correct speed / revs to just be able to drop the lever and not notice the difference...it's a touchy feely thing. but you don't want to hear "Whhrrrrrrrrrrrrrrr....."
Says I, with my wealth of expierience... ::)
Paul.
It hurts to admit when you've made mistakes, But when the're big enough, the pain only lasts a second
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #6 on: October 05, 2005, 07:13:06 AM »
Colin McRae (ex world champ rally driver) once answered this question by saying "it takes 20 seconds to change the brake pads but 30 minutes to change the gearbox - always use brakes"  !!
That's fine for a rally driver with quick change parts and a backup crew. I use engine braking as it gives more control when entering a bend.
As for gear changes, I'm a great believer in clutchless up-changing (I once put this to a VFR-rider mate of mine whose response was "I diidn't realise there was any other way" !!
Clutchless down-chages are a different matter. I've been riding for 30 years and have never managed to master this.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
« Reply #7 on: October 05, 2005, 07:42:10 AM »
I use engine to control speed, and brakes just sparingly to adjust speed or to take the vehicle to a standstill. Yesterday my car give me a warning about replacing the brake pads. They are still the original ones, and the car have 105.000 km in the odo (about 60.000 miles).
The good thing about engine braking is that you still have the brakes as a back-up in case the unexpected appear.
Raul
Offline Mark M
« Reply #8 on: October 05, 2005, 08:19:12 AM »
The idea is not to overstress anything.
If you use engine braking it won't damage the gearbox, it's changing down too early that will do that (valves too if you realy try). On clutchless changes an instructor once suggested that instead of blipping the throtle you could just hold it constant. The idea being that the revs will rise as the gerbox disengages, thus rising the revs to match the new gearbox speed. You weight the gearlever just before slipping the clutch a little and it drops in the moment the drive is lost. It works quite well but after 20 ...odd years I'm quite happy with the blip and ease in method. Perhaps if I was going racing I would find a difference.
douglascoolgrey
« Reply #9 on: October 05, 2005, 08:57:38 AM »
On the other side of the coin, which would you rather have fail unexpectedly: the gearbox or the brakes?
I've never eaten a clutch or broken a gearbox, and I downshift all the time on both cars and motorcycles. I try to never downshift when I'm rev'd so high the bike jerks or shutters. My 550 has a nasty habit of locking the back wheel on sudden stops. Maybe it is protecting its own gearbox.
Offline Uncle Ernie
« Reply #10 on: October 05, 2005, 09:19:49 AM »
First of all, using engine braking is the same as using the rear brake as far as braking forces go. Around 75% of your stopping power is in the front brake, however. Don't ever be afraid to use the front brake. Excersizes in parking lots help to get to know your bike in this respect.  Some bikes (like my Guzzi) benefit greatly by the use of a little rear brake when entering a corner, for example. If you are locking up the rear wheel for any reason, I'm sorry, but you're out of control; either the ground is slick, something is wrong with your brake, or you're not using enough front brake to begin with.
Racing bikes have owners who ecpect to rebuild/fix things constantly, but speed and handling are their only concerns. It takes a lot of intensive training to understand how to ride like that and they still get hurt. I hear that tracks are "safer", but they aren't- they just have a different set of dangers. I don't have stats, but I suspect percentage-wise, there are actually more injuries on the track.
Personally, I use my front brake much more than my rear, and I shift constantly- using my clutch. It takes practice to get good at matching engine and gear speed when downshifting. I drive the throttle with my thumb while clutching, using the front brake alittle and downshifting (seemingly) all at once.
David Hough also has a couple of good books that I found were easier to understand, especially in a non-racing/real-world forum.
My 2 cents
eldar
« Reply #11 on: October 05, 2005, 09:39:11 AM »
I guess I go with ernie on this. I use my clutch as replacing clutch plates is easier than repairing a tranny and I feel you can get into the power more.  I do a combo of engine braking and brakes. I use brakes to slow down and use the engine as a way to control speed when coasting downhill and maybe sometimes coming up to a stop sign.
MetalHead550
« Reply #12 on: October 05, 2005, 01:32:58 PM »
I believe in using a ballanced amount of engine breaking and the breaks.  I made it a habit to use both breaks in almost all situations since it tends to keep the suspension in ballance and you in control cuz both your tires are getting the same force and traction.  When coming to a stop from speed I will start with downshifting as the revs become appropriate and by the time Im in 3rd or so I begin to slightly ride the rear break while feathering the front break and continuing downshifting.  The idea is to never grab at the breaks but to sqeeze them.  This also applies to emergency situations.  Not too long ago I had a couple deer run out in front of me while doing 65 down a country road and luckily I was in the habit I described, and instead of slamming the breaks I found myself squeezing both breaks without locking up and downshifting like a mad man.  Never lost control and came to a creep in a matter of seconds.  Use of both breaks it also important in the turns to as far as setting yourself up for a hard turn.  Gotta keep that suspension level and only feather the breaks if you must while in the turn.  Another trick is if you find yourself going through a corner to fast and you know you cant hold it, throw your knee into the tank a bit and you will find it produces a kind of gyro effect that may save your ass.  Try it sometime in a non emergency situation, say in high speed lane change.  Im not saying blast your knee into the tank but if you ride as I do with your knees firm against the tank, and you wanna go left, press your right knee into the tank as you lean left and press the bars right.  May not have the same effect on other bikes but man...the 550, shes where you want it in a heartbeat!  Ha! ok Im done...
Offline Mark M
« Reply #13 on: October 06, 2005, 02:05:02 AM »
Oh no don't get me onto steering.
You can not steer a bike with body weight. Like most people who have read up on the subject it's hard
to believe at first. But once you try and ride with the steering locked up you will become a believer. I managed
to lock mine by coming up with a bright idea. I put my ignition switch on a 4" length of chain so that the rest of the keys in the bunch droped down below the top yolk so that they didn't scratch it. What a F@@@ing stupid idea that was. The keys wedged in the steering and I was only able to go in  a straight line, very frightening. The Californian superbike school have a bike with two sets of bars, the second is just bolted onto the frame so that you can experience the total loss of directional control once you cant turn the front wheel, scary.
Offline Uncle Ernie
« Reply #14 on: October 06, 2005, 06:32:29 PM »
"...keep the suspension in ballance and you in control cuz both your tires are getting the same force and traction."
Sorry Metal- when you're slowing/stopping your weight is shifting forward; there is more weight on the front wheel, which is why you have more braking power in the front brake. Conversely, the rear wheel is lighter and that's why it's so easy to lock it up and go into a slide.
As far as turning goes, if you push right, you go right.
                                                          ... here we go again  ::)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #15 on: October 06, 2005, 06:51:28 PM »
Here is a photo of the training bike refered to above.
    • TVAM
« Reply #16 on: October 07, 2005, 02:25:16 AM »
Ernie - after reading that stuff about "push the right bar gently" on a thread here a while back, I tried it.
Holy crap it really works!  30 years I've been riding these bikes and I've never really considered the physics of steering. It just seems counter-intuitive to state that "push the right bar will make you go right" - but it does...
SOHC4 Member #2393
2015 Tiger 800 XRT
    • TVAM
« Reply #17 on: October 07, 2005, 02:26:21 AM »
Mark - I've ridden off with the steering lock on (haven't we all at one time?).
Does that count?
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline Mark M
« Reply #18 on: October 07, 2005, 02:54:46 AM »
Steve,
Er........No and ......No.
Now disc locks are another matter!
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
« Reply #19 on: October 07, 2005, 06:45:02 AM »
Brakes are cheap, Clutches are not.
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
ElCheapo
« Reply #20 on: October 09, 2005, 09:48:05 PM »
I try to do both with the exception of my CX 500, which has next to no brakes at all. You can stop nice at 10mph or less after that well you know the sound of needing brakes. And these are just rears. Fronts are non functional right now. Just too lazy to change them and I don't ride it much right now anyway. Last week country road 70mph. If you're careful and don't beat the clutch and transmission it is easy to do without over shifting.
Just another part of my insanity... I'll go weave a basket now.
Offline cb350f_rider_73
« Reply #21 on: October 26, 2005, 07:57:53 AM »
Engine braking does get the job done, but as someone who has replaced a tranny in a bike before, I would rather replace the brake pads.  There are also several other valid points, all mentioned earlier in this thread, such as how 70% of your braking power is in the front brake.  My thought is this:  wouldn't be a good idea to be in the habit of using maximum braking at all times, so when you need it you automatically go for it?  That's what we teach over in the MSF courses.
Wayne
1966 Honda CL77 Scrambler
1973 Honda CB350F (see avatar)
1979 Yamaha XS11 Special "The Beast"
Offline DRam
« Reply #22 on: October 26, 2005, 08:19:33 AM »
Do you mean the maximum amount of brake needed to stop you in a reasonable distance, or do you mean a tire-howling, barely controlled stop at every stoplight?  To me 'maximum braking' means the latter, and I only use it when a car or deer threatens me with imminent destruction.  I do use the engine, front brake and rear brake for every stop so that it is an automatic action.  That has saved my bacon several times when an emergency stop was accomplished without having to figure out what to do while approaching an obsatcle.
Jim Shea
« Reply #23 on: October 26, 2005, 10:22:59 AM »
I agree, front brake, rear brake and engine every time..
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #24 on: October 26, 2005, 11:46:08 AM »
Makes that three of us I guess. One reason I favor engine braking also is that you are likely to keep the appropriate gear you need at any given speed as you are decelerating so if need be, you have some acceleration capability if you should need it. If you use brakes alone and save the down shifting until the last moment(s) you would likely be in too high a gear should you need to accelerate. Hope this makes sense.
