Author Topic: cb550 head gasket  (Read 8733 times)
-Pod-
cb550 head gasket
« on: January 26, 2009, 04:11:38 PM »
My 1975 CB550 is startin to get a bit leaky at the upper head gasket and turning my shoes and socks oily brown.  What is the best way to deal with this.  I also have another 550 motor (very new but at home in Portland, Oregon.  My 550 is in AZ) Would it be best to ship the new motor down and install or deal with new head gaskets in the old one?  Is it also possible to tighten everything down to slow the leakyness?  Maybe use thicker oil? I live in Portland and come down to AZ in the winter to ride my 550 (I have 2 750s up in Portland for summer) I'm willing to spend a whole day to make this work.  Just looking for sensible oppinions that may help me decide the route I should take.  Thanx to all, -Pod-
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
Re: cb550 head gasket
« Reply #1 on: January 26, 2009, 04:22:13 PM »
Have you isolated the leak? If it is coming from the
head gasket you may get away with just a re-torquing.
The tachometer seals are also notorious for leaking so look
there also.
Bikes parked out front mean good chicken-fried steak inside.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: January 26, 2009, 04:24:04 PM »
Welcome to the club, Pod!
If you can live with the leak, that would be your cheapest option.  You can cram paper towel or even cotton clothes line between the fins to make it more tolerable.  I'd hate to see you tear into an otherwise perfectly sound motor just for the oil leak.
On the other hand, if the leak is beyond annoying and edging toward dangerous (slippery controls and/or rear tire) or you suspect a top end rebuild is needed (noisy cam chain, poor compression), then you may want to dive in!
My '77 550k had an annoying/borderline dangerous leak so I'm rebuilding the top end this winter.  You can do a top end rebuild with the motor in the frame.
Plan on more then a day though.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline 1timduke
  • '75 CB550
« Reply #3 on: January 26, 2009, 05:23:37 PM »
I forgot who mentioned it, I'm sure it's an old trick...
I believe they cleaned the area of all the old oil w/ some type of solvent, then dusted everything with talcum powder and rode it to get it warmed up. The talc shows up the oil leak really well.   Sounds like a pretty good way to spot the leak(s) if you're still hunting them with the oily pant leg/shoe method ;D
Could open it up and check the torque on the bolts, probably won't spoil any other gaskets.
A gasket kit and other little things for the top end job isn't too pricey, good weekend project.
But like OldSchool said, check the compression too.   It'd be a shame to fix just a leaky head gasket and put it all back to find out later you've got worn rings or something :P
If it turned out to just be a gasket ($), you could get it all done in a day for not too much effort, basic tools, a little torque wrench and some feeler gauges should be about it.
Of course, then you gotta look at the valves, see if they need a good lappin', that'd be another little bit-o-$$
Check cylinder head for warping, might need planing ($$$) (unless you use the old 'sandpaper technique', only $)
It may not be actually that bad, but the compression test could tell you more.
Also, when you got the head off you can test the seal of the valves w/ acetone.
I'm not sure how to add links, but there's several threads on this site about all this stuff.
I don't know what shipping would be on that engine from Portland, how many stamps would that be... ;D ;D ;D
-Tim
The only thing I miss about the South is Waffle House!
« Reply #4 on: January 26, 2009, 07:57:51 PM »
re-torquing will not work
you need every gasket and "O" ring from base gasket upwards INCLUDING the rubber pucks plus decent tools; patience and time
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #5 on: January 28, 2009, 01:11:17 AM »
Yes you can do this without removing the engine.
Get a manual and follow the instructions.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline neudl
« Reply #6 on: January 28, 2009, 06:09:52 PM »
I concur with the suggestions that you replace the gasket yourself.  It's not hard with a manual and some patience.  I don't have a lot of mechanical experience, but replaced all of the top end gaskets and piston rings last year on my bike.  it wasn't tricky, and it's been great since.  My only advice is to do your research on this site, in that you can damage the valves putting it all back together if you are not careful, and be prepared to put lots of elbow grease into getting the old head gasket off.  I finally had the head and cylinders honed by a machine shop.
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: January 29, 2009, 12:16:07 AM »
You say it's leaking from the "upper head gasket".  Since there's only one head gasket (between the bottom of the head and the top of the cylinders), are you sure it's not just the valve cover gasket that's leaking?  If so, it's much less time and money consuming than a head gasket replacement.
Offline hansi
« Reply #8 on: June 16, 2020, 07:01:53 AM »
Wow. I never thought of this. I have a similar problem with my 550. I was going to use some
Ultra black or something, but this sounds more up my ally.
