Author Topic: 530 chain on a 77 750f  (Read 821 times)
Offline cafe2be
« on: January 27, 2009, 05:57:18 PM »
I know stock is 630. What is the advantage of swapping a 530 with appropiate gears? Just curious.
eldar
Re: 530 chain on a 77 750f
« Reply #1 on: January 27, 2009, 07:06:19 PM »
More gearing choices. Better availability for sprockets and chain. Generally a little lower cost. Lower weight so a little less rotating mass. Better performance? Maybe, hard to say.
Offline cafe2be
« Reply #2 on: January 28, 2009, 05:51:01 AM »
How will it effect the gearing? Better on the street? Better on the highway? 630 oring chain is $100, 530 oring with new sprockets is $130. Seems to make sense to buy the 530, just wondering what the overall difference is. I am not racing the bike, or looking for quick accel.
Thanks
eldar
« Reply #3 on: January 28, 2009, 06:15:02 AM »
Not so much better. You just have a bit wider range of choices. On the K bike, stock gearing was 15/41. The earlier K bikes had a 48/17 if I remember correctly. So they had a tiny bit more accel but were also a bit buzzier at highway speeds. I switched to the 48/17 and did not really notice anything. So for me, it made no difference. Cost was a bit less and thats all I got out of it. Others have different opinions but I did not list opinions initially, just basic stuff that is different.
Offline cafe2be
« Reply #4 on: January 28, 2009, 06:17:02 AM »
eldar, thanks for the response. I guess thats what I was looking for. I am trying to achieve a good highway cruiser.
eldar
« Reply #5 on: January 28, 2009, 06:29:04 AM »
For a highway, I might stick with 630. The gearing is slightly lower. You could do 18/47 which would lower the rpm but in the earlier bikes, gas economy actually suffered. I cant say if it will on your as the later K bikes made more power than the k4 did.
Offline cafe2be
« Reply #6 on: January 28, 2009, 07:43:39 AM »
thanks for the advise eldar. This really helps alot.
