Author Topic: vfr 750 pistons into sohc 750  (Read 3014 times)
Offline dusterdude
« on: January 28, 2009, 09:18:03 AM »
ive been told that vfr 750 pistons will work in our sohc`s to give about 900 cc`s.can anyone confirm or deny this?if so,what years?thanks
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Re: vfr 750 pistons into sohc 750
« Reply #1 on: January 28, 2009, 01:55:10 PM »
Mark,
You might want to check the VFR pin diameter, the VF500F pin is 16mm so I expect the 750 is larger also.
Offline dusterdude
« Reply #2 on: January 29, 2009, 01:02:06 PM »
thanks,ill keep that in the back of my brain.pj told me to use gs1000 pistons which are 70mm.so thats another route too.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline turboguzzi
« Reply #3 on: January 29, 2009, 01:50:54 PM »
they are also a 4 valve design, rather flat and 750 sohc's need quite a bit of dome for a decent CR but who knows....
maybe tell us who told you?
TG
PS Bwaller, think I found you 60mm pistons
« Reply #4 on: January 29, 2009, 04:52:13 PM »
Oh really TG, I may have to kiss you on the lips  ;D
Offline moham
  • .fnord.
« Reply #5 on: January 29, 2009, 05:24:45 PM »
wow.
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline turboguzzi
« Reply #6 on: January 30, 2009, 02:28:13 AM »
let's not get carried away
try these
Honda VTR250 1988-1990
60mm bore
« Reply #7 on: January 30, 2009, 03:37:26 AM »
Don't worry, I don't give it up that easy!
I'll look into those, thanks.
« Reply #8 on: January 30, 2009, 07:39:04 AM »
For those that give a rats ass the VTR 60mm piston also uses a 16mm wrist pin...... crap!
« Reply #9 on: January 30, 2009, 08:21:48 AM »
So how do they look otherwise?? i have bored  out lots of small ends for a few reasons..
Offline turboguzzi
« Reply #10 on: January 30, 2009, 12:42:07 PM »
And I have the opposite problem
turns out that Kitaco has some really cool 57mm pistons for little honda's big bore kits but they all have 14mm pins....
sounds easier to enlarge the piston hole, the bugger is doing the spring ring groove!
TG
billybobobrain
« Reply #11 on: January 30, 2009, 12:50:48 PM »
60mm? = 900, on a 750? Sorry to bust a bubble 836 kits are 65mm.
« Reply #12 on: January 30, 2009, 01:55:10 PM »
bobobrain, we completely derailed dusterdudes first post. He was talking about VFR750 pistons making 900cc's.
The 60mm's are for the CB550.
So bubble burster....no harm done.
billybobobrain
« Reply #13 on: January 30, 2009, 02:10:21 PM »
Wow I must have missed something!
Sorry to be so ignorant.
« Reply #14 on: January 30, 2009, 07:00:32 PM »
smaller is easy.. bronze bush in the small end....easy...
Offline turboguzzi
« Reply #15 on: February 01, 2009, 11:42:57 AM »
Yes, bushing is an idea, just have some doubts about the strength of a bushing that is 0.5mm/0.02" thick.
Reaming the piston gudgeon pin boss to +1mm with an adjustable reamer doesn't sound too hard.
TG
« Reply #16 on: February 01, 2009, 12:41:16 PM »
Tho I have not had a chance to measure, the bushes used appear quite thin..
I have this theory I use often, if a pice is fitted right, ie wont be loose, and made of tough material, (bronze is), then it has nowhere it can go and should work!
 Re making bigger bore in pistons, lots of chance to screwup..&
unless you use buttons, there is a large amount extra work on redoing the circlip grooves.
Have you ever removed .040 from anything with an expandable hand reamer? you would be lucky to do it in an hour per piston, and it can get exhausting.
I do a bit of work for engines shops, on changing size of small ends.. usualy it involves me boring out all but the last .003thou on a mill, then the rod is finished on a hone..
My thought is, bushing the small ends, there is no way to screwup the actual expensive parts, wurst is you loose a few bushings..FWIW...
Offline fang
    • Food Renegade
« Reply #17 on: February 01, 2009, 01:11:13 PM »
Check out this discussion:
http://forums.sohc4.net/index.php?topic=45040.msg472779#msg472779
EDIT:
check out this one over at Satanic Mechanic too.
peace and grease
-fang
« Last Edit: February 01, 2009, 01:15:13 PM by fang »
Download Nervous Norvus' "The Fang"  HERE.
Tired of eating CRAP!
