Author Topic: what rear axle spacers do i need? ... (PICS ADDED)  (Read 1598 times)
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« on: January 28, 2009, 03:04:45 PM »
hey guys, i need some help figuring out what axle spacers i need for my bike. The rear is a 76 rim i believe with a 78 cush drive. do i need the spacer for the cush side to be 78 and the right side (brake side) to be 76? or do i just need 78 spacers?
« Last Edit: January 29, 2009, 12:20:57 PM by midnight08 »
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
KingCustomCycles.com
Re: what rear axle spacers do i need?
« Reply #1 on: January 28, 2009, 03:23:25 PM »
couldn't tell ya on that one but i do know the chain alignment is key, everything else may be compromised within reason.
« Reply #2 on: January 28, 2009, 03:43:53 PM »
I forgot to mention that the 78 cush drive is because the bike has a 78 motor in it.
76 750F bike
78 750F motor
76 750F rear spoke rim
78 750 cush drive
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Alan F.
« Reply #3 on: January 28, 2009, 05:01:15 PM »
If memory serves, the 78 K's spacers are 35mm and 25mm, not sure about the earlier bikes, I'll have to go measure the spacer from my K3.
Offline KB02
« Reply #4 on: January 29, 2009, 04:20:20 AM »
What year wing arm are you using? The 76?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #5 on: January 29, 2009, 08:07:51 AM »
its the 76 swing arm as far as i know... i can go out and put the rear wheel assembly on and see if i can get a ballpark measurement if that helps. but the motor isnt in the frame so i cant get the chain lined up to be accurate
« Last Edit: January 29, 2009, 08:20:50 AM by midnight08 »
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #6 on: January 29, 2009, 08:47:37 AM »
Just throw the wheel on for now, then with engine in check alignment.
You do have the spacers from both wheels? probably will use the 76 sprocket side spacer if you have to spread the swingarm a lot to get it in, trim it.
alignment should be done on bike, not by keyboard.
« Reply #7 on: January 29, 2009, 10:32:00 AM »
i dont have the spacers from either. the po had a comstar on it
VISIT OUR WEBSITE!
Facebook:
Instagram:
Re: what rear axle spacers do i need? ... (PICS ADDED)
« Reply #8 on: January 29, 2009, 12:23:55 PM »
looks to just just under an inch without the bolt tightened down....
maybe something around like 27mm or so.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Quartza
« Reply #9 on: January 29, 2009, 03:12:31 PM »
you are forgetting about the brake caliper holder which is about 29mm wide.
« Reply #10 on: January 29, 2009, 03:19:19 PM »
i am. thank you. hahahaha.
I amaze myself sometimes.
VISIT OUR WEBSITE!
Facebook:
Instagram:
