Author Topic: Rear brake lever adjustment tab  (Read 666 times)
Offline mmtsquid
« on: January 30, 2009, 06:28:59 AM »
Long story short, the tab that houses the screw that adjusts the rear brake lever is bent to hell and back.
I need to grind it off and replace, but it's so trashed I'm not sure what the dimensions are.
If anybody has a 77/78 cb550K, would you mind measuring the dimensions of the tab, and finding the center of the hole relative to 2 edges?
Thanks a lot men!
77 CB550K4
Offline mmtsquid
Re: Rear brake lever adjustment tab
« Reply #1 on: February 09, 2009, 08:08:36 AM »
Bump?
77 CB550K4
Offline Alan F.
« Reply #2 on: February 09, 2009, 05:12:48 PM »
The shop manual I downloaded for my 750 has a measured frame drawing....maybe a 550 manual will have the info you need??
