Author Topic: Name that part! CB 750  (Read 2661 times)
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« on: January 30, 2009, 02:34:36 PM »
Anybody know what it is? I have had this thing for about 10 years and never seen another like it. I know what it is and it is specifically for the CB 750.
 Any guesses?
 There is no prize awarded to the winner.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: Name that part! CB 750
« Reply #1 on: January 30, 2009, 02:46:48 PM »
I have about 5 ideas...
Where does it bolt?
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #2 on: January 30, 2009, 02:54:07 PM »
It looks like one rearset bracket, and a couple of other related linkage bitsas.
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline Really?
« Reply #3 on: January 30, 2009, 03:19:27 PM »
Me thinkin' same thing.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline mcpuffett
« Reply #4 on: January 30, 2009, 03:58:44 PM »
Does it have something to do with forward controls?
« Reply #5 on: January 30, 2009, 06:58:36 PM »
I agree with forward controls ... frontsets...
Offline HavocTurbo
  • Can you tell?
« Reply #6 on: January 30, 2009, 08:06:38 PM »
That's about where I was going...
09 XL883L - No Name
Offline mrbreeze
  • Not your average
« Reply #7 on: January 30, 2009, 10:31:45 PM »
Looks like the right side top motor mount with a provision for a highway peg.
MEMBER # 257
Offline fishhead
« Reply #8 on: January 31, 2009, 05:51:42 AM »
Heres another picture of it put together. It should be easier to figure out now.
 EDIT; Not a foward control, not a rear set or a foot peg mount. It bolts to the engine (somewhere on it). It is mechanical and specifially does something.
« Last Edit: January 31, 2009, 07:23:46 AM by fishhead »
Offline goon 1492
  • Sucka Repellant
« Reply #9 on: January 31, 2009, 05:57:37 AM »
I am going with forward controls and a highway foot pad mount.
dude your avatar keeps making me want to go watch cannon ball run....."Wheres the Paitent!!!"
And captain chaos! Da da DAAAAAAA!!! ;D ;D ;D
« Reply #10 on: January 31, 2009, 08:10:30 AM »
Jock E Shift..?
Offline mystic_1
  • 1970 CB750K
« Reply #11 on: January 31, 2009, 08:29:18 AM »
Sure looks shifter-related, given the splines.
mystic_1
- John Augustus Shedd
Offline wrenchmuch
« Reply #12 on: January 31, 2009, 08:44:05 AM »
Steering damper mount ???
CB750K1
CB750K4
« Reply #13 on: January 31, 2009, 08:50:33 AM »
Some sort of hand shifter conversion for a chop?
Offline mystic_1
  • 1970 CB750K
« Reply #14 on: January 31, 2009, 08:51:10 AM »
OK, I think it reverses the shift pattern.  One up, four down.  A racing accessory, perhaps?
mystic_1
Offline Soos
« Reply #15 on: January 31, 2009, 09:24:07 AM »
air shifter mount plate.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline voxonda
« Reply #16 on: January 31, 2009, 09:28:58 AM »
mystic_1
I am with Mystic!
« Reply #17 on: January 31, 2009, 09:38:05 AM »
Part of a right hand shift conversion for flattrack or old britbikedogs & Sportsterdogs, that cant learn new tricks...
Offline WFO
  • Will work for powerbands
« Reply #18 on: January 31, 2009, 09:41:00 AM »
Iam going to go out on limb and say it's a motorcycle part.  ;)
82 cb650 sc nighthawk - 78 kz 650 b
Offline mcpuffett
« Reply #19 on: January 31, 2009, 11:10:24 AM »
some type of parking brake mechanism? or security device?  :-\, cheers Mick.
Offline Patrick
« Reply #20 on: January 31, 2009, 11:40:09 AM »
It is clearly a doohickey.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline fishhead
« Reply #21 on: February 01, 2009, 05:23:55 AM »
mystic_1
 Mystic is correct.
   It's either a:
  1) reverse pattern shifter mechanism (for std.mounting of gear lever) or
  2) shift pattern "corrector" for rear sets using the Std shift lever mounted in facing rearwards position.
 I'll post a pic of it mounted in a few days. I came down with the flu and am stuck inside for a few days.
Offline mystic_1
  • 1970 CB750K
« Reply #22 on: February 01, 2009, 07:21:19 AM »
Woohoo!  I won the no-prize!   ;D
mystic_1
