Author Topic: longer swingarm for cb550  (Read 2403 times)
Offline unkle fester
« on: February 01, 2009, 03:27:00 PM »
what swingarm that is longer will work the best for a cb550??....I like the look of this bike but that's not the stock swingarm on it......any suggestions???........thanks
Offline fastbroshi
  • Puppet
Re: longer swingarm for cb550
« Reply #1 on: February 02, 2009, 09:28:25 AM »
  You did know that's a 400 in that pic right?  Could be a later 550 swingarm.
Just call me Timmaaaaay!!!
« Reply #2 on: February 02, 2009, 05:08:02 PM »
yeah....knew that....I want to do a 550 similar to that though......by looking at the shock angles, I'll need a little longer swingarm on the 550.........
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #3 on: February 02, 2009, 05:49:06 PM »
You looking for straight bolt on or something you could modify?
Because you could technically modify anything to fit the length you are looking for.
Maybe a later 750 swing with some trimming??
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline fastbroshi
  • Puppet
« Reply #4 on: February 02, 2009, 05:54:32 PM »
   Just a hint, YZF600R swingarms are about 2-3 inches longer and VERY close width wise at the pivot.
Offline d3buttz
  • More than just an
« Reply #5 on: February 02, 2009, 06:01:19 PM »
i had a 750 parts bike and was gonna try its swing arm for my 550, but theyre the same length too.
http://forums.sohc4.net/index.php?topic=80508.0
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1996 Nissan pathfinder
1972 Datsun 240z
2002 Nissan sentra se-r spec-v
« Reply #6 on: February 02, 2009, 08:54:24 PM »
I lengthened one for my 750. I cut the middle of the flat area behind the bearing area. Then inserted 1 1/4 angle into the swing arm legs, mig welded that into the legs and to the front section. i left a gap equal to the stretch I wanted and tig welded plate over the gap. the edges are a bit of a challenge to get looking right so I boxed it square and welded it up. One saturday morning. CLEAN off the paint before welding it is nasty if you burn it and will make you sick. I was able to leave the brake bracket and slice the weld from the front part and re weld to the new plate.
Offline Soos
« Reply #7 on: February 03, 2009, 07:12:12 AM »
Have you looked at a '80-'82 cb650 swingarm?
I used one of those to get a longer swingarm than the stock '79 cb650 uses.
Not a straight across swap, but it works well with a set of custom bushings.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
« Reply #8 on: February 03, 2009, 06:02:31 PM »
10-4..........thanks........I'll have to check into a cb650 arm.....................
Offline BlindJoe
« Reply #9 on: February 03, 2009, 06:18:03 PM »
1982 cb1100f, you'd have to make some spacers though
Offline jeepurz
« Reply #10 on: February 04, 2009, 10:02:35 AM »
hey fester, I dont get on here much but wiseguy did one for my 550. I also donated a 750 to set up a jig for him, you might give him a yell. Ive also got a 500 ninja, but cant remember how it measured , it did fit between bosses. ld part with it ya need it shoot me a pm. Ive got 28 bucks in it without shpping. (no axle or sliders.).
