Author Topic: parts for cb 500 four  (Read 758 times)
Offline limp1969
« on: February 02, 2009, 05:38:04 PM »
where can get a set of standard rings, valve seals and top end gasket kit for a cb 500 four also same for a cb450 t
1971 cb 500
1972 cb 350
1972 t100r
1972 gt550
1973 t140v
1974 gt185
1977 rd400
Offline OldSchool_IsCool
  • Really feeling like an
Re: parts for cb 500 four
« Reply #1 on: February 02, 2009, 06:08:31 PM »
I got a top end set from http://www.westernhillshondayamaha.com/default.asp a few years ago.  Call and ask for Terry at the Vintage Parts desk.  The kit I go did not have sealing rubbers (pucks) or the valve guide seals.  They should also be able to hook you up with standard rings too.
If not, you can try www.servicehonda.com Good prices and reasonable shipping.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline neudl
« Reply #2 on: February 03, 2009, 09:19:06 AM »
I got a set of CB500 rings from Cycle-Recycle last year.  Standard rings were not easy to find.  The only downside was that they were mis-adressed and floated around in the postal system for over a month before being returned to Cycle-Recycle and the mistake was corrected.  Top end gasket kit is the same as a CB550.  I picked up a set of Athena gaskets at Bike Bandit, and have had no problems.  Came with the pucks too.
« Last Edit: February 03, 2009, 09:20:58 AM by neudl »
« Reply #3 on: February 03, 2009, 09:27:46 AM »
Well if the top end kit is the same as the 550, then read this thread.  It's my rebuild thread now that I have my motor apart.  It has a lot of part numbers sprinkled throughout.
http://forums.sohc4.net/index.php?topic=44637.0
Sure.
Is it hard?
