Author Topic: Now, THis One I'd Like To Know The Details Of.  (Read 2159 times)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« on: February 02, 2009, 05:38:18 PM »
      Probably too much machine work to accomplish, but I sure would like to know the details of what it took to put the 450DOHC top end on that Super Hawk lower end And how it performed. 8) ;) I mean I've got the basic parts but, not the know how or the expertise to accomplish it. I also saw (somewhere, where someone took the top end of a Suzuki GS400 (also a DOHC) and mounted it on a Super Hawk lower end. I can't find where I saw that though.
Member # 1969
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: Now, THis One I'd Like To Know The Details Of.
« Reply #1 on: February 02, 2009, 05:47:27 PM »
God.... again with the dry clutch conversions.... I might have to turn on my mill yet...
Wait... maybe MEC could cook something up. Seems he has LOTS of free time  ;D :P ;D
Just kidding MEC.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline bill440cars
« Reply #2 on: February 02, 2009, 06:39:06 PM »
Just kidding MEC.
                                      :D ::) ;)
Member # 1969
« Reply #3 on: February 02, 2009, 07:00:24 PM »
It's the bike I was telling you about last week in another thread.
It was built by a mate of mine named Pete Rhodes a few years back.
I'll ask him for details if I see him.
I looked all over the net for that thing last week. ::) ::) ::)
Sam. ;)
Offline bill440cars
« Reply #4 on: February 02, 2009, 07:02:08 PM »
HavocTurbo said,
         "God.... again with the dry clutch conversions." :)
         Well, Don't look at this one then. ::)
CR77 Replica Specifications
Engine type: .................. Four stroke twin, 180 degree firing DOHC with two valves per cylinder
Bore & Stroke: ................ 65 x 54 mm
Power @ RPM: .................. 52 BHP @ 12,000
BEMP: ......................... 175 PSI
Power Band: ................... 8,000 to 12,000 RPM with a safety zone of 1,500 RPM extra
Primary Drive: ................ Straight cut gear w/idler, 19-63 (3.31:1)
Clutch: ............................ Multi-plate, Dry
Transmission: ................. Five speed, constant mesh
Gear Ratios: .................. (1) 1.898 (2) 1.459 (3) 1.254 (4) 1.192 (5) 1.000
RPM Drop @ upshift: ........... (1) 27%, (2) 21%, (3) 11%, (4) 8%
Ignition: ..................... MotoPlat Magneto, pointless ignition one sparkplug (14mm) per cylinder
Carburetion: .................. Two Keihin 31mm smoothbore, dual cable operated. Main Jet #110, Jet Needle # RH3, Needle Jet 2.6mm, airbleed type, air jet #250, pilot jet #55, cutaway 2mm, float valve 2.5 mm
Oil Pump: ..................... Twin gear type, low volume, supplying engine and transmission.
Valve Diameters: .............. Inlet 23.6mm, Exhaust 22.0mm
Port Throat Diameters: ........ Inlet 21.0mm, Exhaust 18.7mm
Valve Lift: ................... Inlet 7.0mm, Exhaust 6.0mm
Valve Springs: ................ Dual 70-80lbs on seat, 120-130lbs open
Valve Overall Length: ......... 100mm
Valve Guide Length: ........... 55mm
Valve Weight: ................. 26.9 gm (With retainer, keepers, and 1/3 of spring weight 79.6 gm)
Member # 1969
Offline bill440cars
« Reply #5 on: February 02, 2009, 07:08:57 PM »
Sam. ;)
         Sorry Sam, I had had a "Senior Moment" and it just slipped away! ::)  Sure would appreciate knowing some more about that one. I mean, it's not like I'd ever be competing against him. ;) I did find a thread over on the 305 forums where a fellow would like to build a 500cc out of one of those engines with the 305 lower and the 450DOHC upper. :o
Member # 1969
Offline HavocTurbo
  • Can you tell?
« Reply #6 on: February 02, 2009, 09:44:40 PM »
WTF BILL!!!!
Again with the dry clutches..... can you see my weakness yet??
Sigh....... If only I had more shop space.
09 XL883L - No Name
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #7 on: February 02, 2009, 10:52:32 PM »
Bill, what do those CR77'S weigh, give or take?
52 hp @12K... geez!
1974 CB550K
                                  Your 1%er name
Offline dusterdude
« Reply #8 on: February 03, 2009, 07:24:46 AM »
bill,there is a guy named hondamatic on the dragbike.com forums,who is putting a suzuki head of some type on a honda twin of some type,interesting read.you should check it out.i think its in the other bikes section.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #9 on: February 03, 2009, 02:36:32 PM »
Sam. ;)
yes it was like the picture I posted last year after Uttoxeter VJMC Show, I spoke to him and found he knew you Sam, I recommended Bill asked you for more details then.
edit my post http://forums.sohc4.net/index.php?topic=38195.msg396763#msg396763
« Last Edit: February 03, 2009, 02:43:25 PM by malcolmgb »
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
« Reply #10 on: February 03, 2009, 03:30:46 PM »
52 hp @12K... geez!
Billy, the bike in the pic is only a look-a-like and not even a replica.
A real CR77 has a bore and stroke of 60 x 54 giving 305.4cc.
The power was only 47bhp at 12,500rpm.
It also had a six speed gearbox not five and had a dry weight of 345lbs.
Sam. ;)
Offline Ecosse
  • Member #4139
« Reply #11 on: February 03, 2009, 04:16:53 PM »
52 hp @12K... geez!
Sam. ;)
Still ain't bad considering my bike is/was rated at 50 and tips in at over 400 lbs.
Thanks for the info sir! Always welcome a skoolin'.
1974 CB550K
                                  Your 1%er name
Offline bill440cars
« Reply #12 on: February 03, 2009, 04:54:06 PM »
    Well, just read email from Ellis Holman and HE is the one who built a CR77 lookalike that used a Suzuki GS400 head and this is the bike. I suppose this is the one that Sam was telling me wasn't a true CR77. Looks pretty decent to me, but, then again, I'm not very up on the details of the race bikes like Sam and some of the others. If I was to EVER have anything that even remotely looked like one of those bikes, it would HAVE to be an attempt at a copy!  ::) ;)
Member # 1969
« Reply #13 on: February 03, 2009, 06:14:44 PM »
If I remember correctley, Ellis did join the forum a few years back.
I think he has a YB 350 race bike to very early specs, a very nice bike.
His build skills are verry good.
Sam. ;)
Offline bill440cars
« Reply #14 on: February 03, 2009, 07:00:09 PM »
Sam. ;)
          I think you are right Sam, because some time back, I was posting some of the bikes on his website and next thing I knew, YOU were telling me that he was online and I got to have some conversation with him. 8) Very knowledged man and very responsive to emails. I've exchanged a couple with him tonight and one earlier today. Very nice to talk with about the features of one of his bikes and no problem for him to answer questions in very good detail. ;)
Wouldn't surprise me to see him chime in here on this. :)
Member # 1969
« Reply #15 on: February 03, 2009, 07:05:06 PM »
I hope he dose Billy.
Sam. ;)
Offline bill440cars
« Reply #16 on: February 03, 2009, 07:52:23 PM »
Sam. ;)
       I agree, Ellis is pretty easy to talk to, likes to talk about motorcycles and doesn't mind taking the time to answer questions. 8)
          Take care, Bill ;)
Member # 1969
