Author Topic: Octane Requirements for 1973 CB750  (Read 2954 times)
MikeyD
« on: October 06, 2005, 10:04:06 AM »
I have a 1973 CB750k3 and yesterday I inadvertantly filled my tank with 2 gals. of mid grade vs. premium.  I normally fill with premium (93 octane).  Does anyone know whether this difference in octane (89 vs. 93) will make that great a difference in idle, performance, etc. for half a tank?  Additionally, I have a source out here where I can obtain racing fuel (100 octane).  Is this higher octane of any value for the 750's?  Recommendations?  Thanks ....
Offline kyre
    • CB400F / 466 Build Thread
Re: Octane Requirements for 1973 CB750
« Reply #1 on: October 06, 2005, 10:07:37 AM »
Unless you've done major mods to the engine, 87 is just fine for these old bikes. I used to run 93 in my bike but since the gas prices are so high I've been using 87 for the last year with no difference in performance.
CB400F / 466 Build Thread (currently in progress)
http://forums.sohc4.net/index.php?topic=105027.0
Offline bistromath
« Reply #2 on: October 06, 2005, 10:09:03 AM »
No need for 93. I try to get good gas (Shell, Chevron, Mobil) instead of no-name stations, but the higher octane mix won't make any difference to your bike.
'75 CB550F
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #3 on: October 06, 2005, 10:10:18 AM »
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline Geeto67
  • A grumpy
« Reply #4 on: October 06, 2005, 11:13:58 AM »
I run 87 most of the time. Only in the summer on hot days will I run 93 octane. the reason I run the premium is that I do a lot of city riding and sometimes get stuck in traffic. On hotter days the extra octane helps prevent detonation from overheating (rocks in a coffee can sound).
Maintenance Matters Most
Offline Jonesy
  • Shop Rat
« Reply #5 on: October 06, 2005, 03:32:18 PM »
I have a '73 CB750 and the owner's manual originally called for 91 octane, but that was under the old rating system. The modern 87 octaine by the current R+M/2 method (refered to by Honda in later manuals as "Pump Octaine") is equivalent to the "old" 91. I usually run mid-grade since the combustion chambers are coked up a bit and I get some pinging pulling away from lights.
jurob
« Reply #6 on: October 06, 2005, 03:52:32 PM »
9:1 compression is low and only requires reg unleaded if your timing is not advanced over stock.
