Poll
How often do you lube your drive chain chain?
Every ride
100-500 miles
500-1000 miles
1000+ or when I change oil
2000+
When I replce the chain and fix hole in the case
Author Topic: How often do you lube your chain?  (Read 21459 times)
Offline stresssolutions
  • 4 years on a motorcycle, Time Flies!
  • 03 RoadStar, I miss my Honda
    • bloggy thoughts
Re: How often do you lube your chain?
« Reply #50 on: November 18, 2007, 01:23:30 PM »
I wonder if i am just jerking off.
If you have to wonder and don't really know....why bother?
Sorry, sometimes I think I'm funny....
Enjoying life, one day at a time.
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
« Reply #51 on: November 18, 2007, 01:25:29 PM »
That might stay on the chain longer
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
Offline Hope
  • How did I become an
  • SOHC member since '01
« Reply #52 on: November 18, 2007, 06:03:10 PM »
It's always good to lube up before a long hard ride
Offline edbikerii
    • Gallery
« Reply #53 on: November 18, 2007, 08:22:04 PM »
Well, you're a saucy one, aren't you?  I like that in a woman.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
« Reply #54 on: November 18, 2007, 10:39:16 PM »
LMAO !!!
= Lubing My Acme O-ring................ ;)
« Last Edit: November 18, 2007, 11:04:06 PM by 754 »
Offline RatBikeRandy
  • Yes I Can
« Reply #55 on: November 21, 2007, 06:42:03 PM »
Never touched the O-ring chain on my wife's '92 Suzuki GS500E. It passed through a couple of acquaintances after us and still looks/runs like new.  We put a few thousand miles on it - can't remember exactly how many.  During the same time, I had to adjust the one on my 500 Interceptor 4 or 5 times and lube it - good quality, non O-ring chain.
I am sold on the O-ring chain.
« Reply #56 on: November 29, 2007, 07:08:09 PM »
Now i am really wondering if the lube on an O-ring chain causes more damage due to grit than the lack of oil.???????????
Offline kpier883
  • is quite the
« Reply #57 on: November 29, 2007, 09:07:25 PM »
Silkolene chain lube.  I haven't seen any of this in several years so I don't know if it is still sold.  Seems to be working better than what I was using - Marvel Mystery Oil and clean motor oil mixed 50/50.  But I am lubing more often these days after laying out big bucks for a Tsubaki non oring.
I have noticed that if I go more than 300 to 400 miles in one day, I usually have to adjust the chain.
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
« Reply #58 on: November 29, 2007, 09:21:52 PM »
kpier,
If you are running Tsubaki QR and oiling with gear lube every 3-400 miles..you would not be adjusting very often...
Offline kpier883
  • is quite the
« Reply #59 on: November 30, 2007, 07:34:47 PM »
I don't know if it was a QR or something else, and I don't have the box anymore.  Maybe there is a QR stamped on the side?  I will check it tomorrow.
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
« Reply #60 on: November 30, 2007, 09:08:34 PM »
I adjust my chain every 1500-2000 miles!  Now I really think that oiling is the problem.  I am a very bad about forgeting to oil the chain.  I only did it once this year and the chain is perfect.
« Reply #61 on: December 02, 2007, 07:35:47 PM »
Regardless whether it's an O ring chain or not, you need to lube it. The couple of microns of lube held in between the pin and the pivot tube in each link and sealed in by the O ring, X ring etc, only lubes the inside of the link, stopping it from siezing.
You still need something to reduce the "metal to metal" contact between the outside of the chains rollers and sideplates, and the sprockets. The benefit of having a K0 - K6 CB750 is that additional chain lubing is unnecessary, with our auto oilers!
I just fitted a massive RK 530 X ring chain with new sprockets to my K1 "Power Kruiser" with the new 836 engine, my poor old "non O ring" chain was getting tired, and the last thing I wanted to do was throw a chain at warp speed. It's an endless chain, so a bugger to fit requiring the purchase of a special chain breaker/rivetter tool, but I couldn't get a clip link, which proved to be a pain. I reckon it weighs about twice what my old chain did too, it's enormous! Cheers, Terry. ;D
« Reply #62 on: December 02, 2007, 10:21:31 PM »
Hey T1 I found a master link for my chain.  I just can't remember where I got the chain at this moment.  I like it because I take the chain off and give it a good soaking 2x a season.  That is the reason it has not worn I believe.
« Reply #63 on: December 02, 2007, 11:08:07 PM »
Well if you find a joiner for mine mate, send it over! I've got a 630 O ring chain on my 1981 Suzuki GS1000S that's done 50,000 miles, all because the PO (and I) regularly lubed it. I've had that bike up to 145 Mph and the last thing I'd want is for my chain to let go at that rate of knots! Cheers, Terry. ;D
« Reply #64 on: December 04, 2007, 09:22:14 PM »
I will do that.  It seems to me ZI found it at "The old bike barn"  or some name like that.
T2
Offline ofreen
« Reply #65 on: April 27, 2008, 11:39:56 AM »
Here's an update to the WD-40 experiment.  After 8500 miles since new, I've adjusted the RK chain on the 750 for the first time since the adjustment I did at around 200 miles.  It didn't take much, just turned the adjuster bolts two flats.  The sprockets look good and chain still runs quietly.  The nice thing has been how clean everything is staying.  So far, so good, so the experiment continues.
How about an update, year or so later??
Two years since I posted an update on the WD40 experiment already.  Jeez, time flies.
The chain and rear sprocket are doing fine. A couple of months or so ago, when the chain/sprocket set (RK 530 o-ring/Sunstar 18/48) were at about 16,000 miles, I noticed I was getting increasing noise from the front, rattling a little when I pushed the bike with the engine off.  When I checked, the countersprocket was worn quite a bit. For obvious reasons, the countersprocket wears faster than the rear, but my impression was that the wear was more than I used to see when I used Maxima chain wax.  Not a lot more, but still more wear.  I had another Sunstar countersprocket laying around with about 1000 miles on it, so I swapped them out.  At that point I went back to using Maxima chain wax.
The RK chain and rear sprocket now have a little over 18,000 miles on them now, and it appears they will go a lot farther.  I have been getting 20,000-25,000 from the same combination on this and other bikes in the past, and these  will probably go that far, too.  It is a little uncertain drawing conclusions from just one chain/sprocket set, but I have anyway.  My impression is that the chain and rear sprocket show no adverse effect from the use of WD40, but the countersprocket probably benefits from a lube that provides a little more cushion.
For those that haven't read the whole thread, this is a '75 750F and the miles are mostly commuting in all kinds of weather.
Greg
'75 CB750F
