What I am thinking is that clacking happens when the reservoirs under the cam aren't full. After the motor runs a short time, those reservoirs fill up. Then the #2 and #3 cam lobes splash through the oil regardless of what is coming out of the oil pipes and it quiets up. Of course, if the pipes were totally clogged, the reservoirs would never fill. My other 350 doesn't do it though. So when I get my new top end gasket set, I'm going to watch it. I have another engine, I may yank the oil pump out of it depending what my other one does. I suppose I could just run the electric start with the ignition off for 10 seconds of so but I'd like to figure out what's going on...
