One thing I know about these carbs is they have to be squeaky clean. So it'll run given fuel. If you loosen the drains on all the bowls, does fuel come out? If so, prob a clogged jet.
I take it you've got the stock airbox. What about the exhaust? Is it stock? If not, the jets may need adjustment or replaced w/ a different size.
Sometimes folks will put a float or two in upside down. And the floats need to be able to go up and down freely on their brass pins. But hey maybe you should post your problem in the Project forums, it'll get more views there.
Oh and make sure you got a good charge on the battery. Plugs should probably be NGK D7EA, or ES, can't remember.
