Author Topic: Help with my headlight!!!  (Read 906 times)
DirtyUnderWhere
« on: February 06, 2009, 09:20:44 AM »
Okay, my bike's a 72 cb750 cafe and it's my first classic bike. My taillight has never worked for whatever reason, just no juice to the wire. So when I did my fender elimination, I figured that I would run a wire from my headlight to power the taillight, which worked fine... Until my rear tire ate my tag bracket and taillight. I guess my clearance issues WEREN'T worked out after all. The reulting mass of twisted metal pulled all of the wires out at the splices. This caused the wire that was run to my tailight to ground out (i'm assuming) and now my headlight doesn't work... and therefore the taillight doesn't work either. I've put everything back together and cured my clearance issue by mounting the tag elsewhere. But the light won't work. Everything else does. The headlight bulb is still good. Someone help! I don't believe in taking my bike to a shop if it can be avoided. Is there a fuse I blew?  Any help would be greatly appreciated.
Thanks,
 Alex
DirtyUnderWhere
Re: Help with my headlight!!!
« Reply #1 on: February 06, 2009, 11:42:31 AM »
Anybody???
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
« Reply #2 on: February 06, 2009, 11:52:18 AM »
if it grounded out, it probably blew a fuse. i would check there first. it thats good, check for power to the bulb, from the switch, etc. should be pretty straight forward
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #3 on: February 06, 2009, 02:21:26 PM »
Yep, run down the electrical schematic tracing the electrical path and testing along the way. Check the connectors to the fuses also. Electrical issues can be buggers, get a continuity tester along with a voltmeter.
DirtyUnderWhere
« Reply #4 on: February 13, 2009, 09:22:03 AM »
Okay, so the headlight works again! What did i do you ask? Nothing... The sohc4 gods smiled upon me and the other day when I turned the key it just came on. So I'm gonna leave it be till it goes fubar again. A new problem has arisen though... Valve tappping! I'm gonna start a new thread for that one though. :(
Offline BIKE
« Reply #5 on: February 13, 2009, 09:39:24 AM »
Just don't post on here that you ran into the tree while coming home in the middle of the blackened night. ;D
1975 CB750 K5
1977 CB750A
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: February 13, 2009, 09:41:53 AM »
Problems that "fix themselves" also tend to re-break themselves.
mystic_1
- John Augustus Shedd
DirtyUnderWhere
« Reply #7 on: February 13, 2009, 09:43:39 AM »
True enough, and I think I have quite the wiring issue due to some other electrical gremlins, but it'll have to hold until I get ready to rewire the whole thing (soon).
