Author Topic: honda cb350f reluctant to pull  (Read 2885 times)
edmer79
« on: April 16, 2005, 12:24:26 AM »
the problem start to happens at around 7000rpm.it got worse when i switch to k&n filters(5500rpm).could it be the carbs?main jets?ignition timing?fuel flow? :-[
Offline Harry
    • CB500F
Re: honda cb350f reluctant to pull
« Reply #1 on: April 16, 2005, 12:38:17 AM »
Uhm... yes!
Harry Teicher, member #3,  Denmark....no, NOT the capital of Sweden.
edmer79
« Reply #2 on: April 16, 2005, 12:48:40 AM »
so what do you think is the main problem?
Offline Harry
    • CB500F
« Reply #3 on: April 16, 2005, 12:51:03 AM »
See carb FAQs for description of causes of your symptoms.
El Taco
« Reply #4 on: April 16, 2005, 01:12:03 AM »
Does it only happen at speed? I've heard of people getting poor performance running pods at speed. Otherwise, it never hurts to check your spark advancer. It should move freely and snap back.
edmer79
« Reply #5 on: April 16, 2005, 01:32:47 AM »
it's happen at about 50mph.the problem starts whenever the throttle is open more than 1/4.maybe the carbs need a bigger main jet in relation to the k&n filter i change.there again the problem still exist even with stock air filter(around 7000rpm).what with happen if i advance or retard the timing?
edmer79
« Reply #6 on: April 16, 2005, 01:36:25 AM »
by the way,my cb350f is fitted with newtronics electronic ignition.
don_m
« Reply #7 on: April 23, 2005, 07:04:39 PM »
The stock Honda air filter element is good but very restrictive.  The carburetor main jets are sized to allow for it.  Your symptoms are typical of running without a filter element or running with a foam replacement.  You can go up one jet size to compensate for a free flowing filter.
Don.
