http://forums.sohc4.net/index.php?topic=46084.msg484557#msg484557 The steering stems ARE the same for the 75-77 GL and the 78-79. The only difference between them is the lower triple tree for the 78 has a wider spacing on the fork stop. The 78 changed the outer bearing diameter and the fork stops need to be spaced apart to clear the wider bearings(the frame was bigger where the bearings went as apposed to the early style). The 78-79 also came factory with tapered roller bearings, the 75-77 came with ball bearings (stock). Both stems are close to 9 5/16 inches long.
PICS. The pictures are lacking in detail as my camera is only so accurate at close ups.
1) 78 forks on top, 75 forks on the bottom. The sliders are different as the 78-79 has the caliper mounts closer together. The 78 has the peice of paper taped to it for identification and also has the stock tapered bearings on the stem.
2) 78 GL steering stops (about 93mm apart)
3) 78 lower bearing diameter (30mm)
4) 78 upper bearing diameter (26mm)
