Author Topic: rear axel bolt-safe to reverse??  (Read 787 times)
Andrew Foss
« on: February 08, 2009, 12:35:37 PM »
hello,
i wanted to know if anyone had input as to whether is is safe or not to mount the rear axel with the nut/cotter pin on the left and press it in from the right (opposite from stock). i have a tail light that mounts to the axel but it is meant to mount on the left. it slid together fine and everything, but i dont know if the axel was designed to fit the other way (tappered or something else) and i dont want to ride it this way if it is going to cause an unsafe condition.
thanks,
-andrew
Re: rear axel bolt-safe to reverse??
« Reply #1 on: February 08, 2009, 01:00:03 PM »
hello,
thanks,
-andrew
I've always had mine on the left. 15+ years, 50k+ miles and on road racer. REason? So loosening it was easier and away from the exhaust pipe. Never a problem. Didn't even consider it.
I can see that on a 4 pipe stocker, the factory may have been considering keeping your hands away from the sprocket/chain.
Andrew Foss
« Reply #2 on: February 08, 2009, 01:04:11 PM »
good to know, thanks.
