Author Topic: Where's the common point of failure for the guage, tail, and running lights?  (Read 1321 times)
ThomasTedder
Turn signals, brake, and headlight still work.
Offline fastbroshi
  • Puppet
  Sounds like a bad connection in the headlight shell.  Is that fairing lit or have any extra lights?  If so, the chances go up of a prior owner having modded things shoddily.
Just call me Timmaaaaay!!!
ThomasTedder
It doesn't have a fairing; just a windshield.
Look for the multi-junction connector in the headlight that comes from the headlight switch. Also look for the green multi-connection grounds, as some models had a little "extender" pigtail that plugged into one of the green multi-connectors so it could add 3 more grounds.
One lost wire in either of these can cause that, as can a broken wire.
ThomasTedder
Thanks, I'll check that, Hondaman.
Offline mystic_1
  • 1970 CB750K
I do believe that you'll want to be scrutinizing the Brown/White wires.
mystic_1
- John Augustus Shedd
ThomasTedder
mystic_1
Thanks
ThomasTedder
Turns out there was some corrosion on the fuse terminals. Just had to clean them up a little.
