Author Topic: cb900f  (Read 1257 times)
Offline KRONUS0100
  • MAD MATT THE MANIAC
cb900f
« on: February 09, 2009, 06:02:10 AM »
ok, a buddy of mine bought it....I get to fix it.  DOHC CB900F....on teardown...how do you get the exhaust cam out?  Am I missing something?  There is no releasing the tension on the long cam chain and both the adjusters are backed out completely. Any Ideas.....cutting chain is simple......but I need to also put this back together in reverse of coming apart.
MATT
Offline City Boy
Re: cb900f
« Reply #1 on: February 09, 2009, 07:56:31 AM »
Hi there.If u have not already,lever against X cam tensioner to maximize chain slack and lock acorn lock nuts.Remove sprocket from X cam and slide cam out of sprocket.Have fun and Rock On.
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: cb900f
« Reply #2 on: February 09, 2009, 09:38:16 AM »
Guys on here have DOHC Hondas so will probably be able to help.
You could always ask the experts on www.cb1100f.net or www.cb900c.com
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline KRONUS0100
Re: cb900f
« Reply #3 on: February 10, 2009, 11:28:25 AM »
thanks........turns out the tensioner in question was broken, taking one out of a 900 custom motor.......also found a copy of the factory service manual............nice how they explain more than a haynes or clymer manual.
MATT
