Author Topic: Gouge in top case  (Read 1267 times)
Offline Turbogrimace
    • Draft Cycle Works
Gouge in top case
« on: February 09, 2009, 08:13:46 AM »
I gouged out a slight bit of metal when I was removing the studs from my F bottom end.  I am planning on boring out the top case for larger sleeves and was wondering if I could just use some yamabond or 3 bond along with the base gasket to take care of the gouge.  It is not too deep, but it is obviously deeper than the rest of the mating area.  Any suggestions on how to repair, or should I be fine with some goo?
Thanks!
