Author Topic: Mechanics Dictionary  (Read 1064 times)
Offline Caaveman82
  • Zippo
  • That'll do pig. That'll do.
« on: February 09, 2009, 09:53:20 AM »
I got this in an e mail, it had my crying from laughter.
This is an excellent mechanics dictionary.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room denting the freshly-painted vertical stabilizer which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned  calluses from fingers in about the time it takes you to say"Oh sh--...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion and the more you attempt to influence its course the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt but can also be used as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door, works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also, most often, the next tool that you will need.
Offline j-conn
  • Federico Fabrizi
Re: Mechanics Dictionary
« Reply #1 on: February 09, 2009, 10:33:45 AM »
hehe ;D
1976 CB550
Member #7772
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #2 on: February 09, 2009, 10:41:31 AM »
 :D :D An old one I had all but forgotten, Thanks!
First job as a mechanic I was cleaning a bolt with a wire wheel. It was one of those old big mothers and it pulled the bolt and my right middle finger between the wheel and the metal "protective" shield so hard I jammed the motor. I had to use my free hand to pull my right hand free.
Big gash that for some reason didn't bleed. So embarrassed I didn't say anything and just taped it up. Looking back I maybe shoulda gotten stitches.
1974 CB550K
                                  Your 1%er name
AK Cafe
« Reply #3 on: February 09, 2009, 01:00:18 PM »
Here's a couple you missed! AK Cafe
Boroscope: a flexable inspection tool used to see into confined spaces to determine just how F****d you really are!
4X rivet gun: a pneumatic device for installing perfectly spaced smiley faces into the skin of the wing you just finished reskinning.
Offline benly- ben
« Reply #4 on: February 09, 2009, 01:14:44 PM »
hahahahaha ;D
"Youngest Member On The Forum! Joined When I Was 12!"
Offline tramp
« Reply #5 on: February 09, 2009, 07:00:15 PM »
i have a problem
i understood every one of those
1974 750k
Offline 74cb750
« Reply #6 on: February 09, 2009, 07:10:43 PM »
These are the definitions I should show to my sons!
Laugh at least once a day.
Life  $ucks, then you die.
Offline Caaveman82
  • Zippo
« Reply #7 on: February 09, 2009, 07:36:49 PM »
My favorite was the pliers "some times used in the creation of blood blisters".
Every time, no matter how simple the task, I pick up a pair of pliers I walk away with a blood blister...
Offline j-conn
  • Federico Fabrizi
« Reply #8 on: February 10, 2009, 08:01:38 AM »
ditto  :P
1976 CB550
Member #7772
eldar
« Reply #9 on: February 11, 2009, 08:15:44 AM »
You all forgot the circular saw! Commonly called the skilsaw cause it takes more skill than humanly possible to use it! ;D
Offline Caaveman82
  • Zippo
« Reply #10 on: February 11, 2009, 10:56:04 AM »
I like that! lol
