Author Topic: 17mm vs stock oil filter bolt  (Read 1529 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: February 09, 2009, 02:54:42 PM »
I bought the after market 17mm oil filter bolt shown in the picture below. Comparing it to the stock bolt I noticed the stock bolt's oil flow holes are beveled for better oil flow and the after market one's holes are not. My questions are:
1. Does it matter?
2. If it does matter and I get out my dremel to port the little holes, should I remove the check valve mechanism first and
3. If I remove the check valve mechanism by punching out the set pin, is it difficult to get it back together?
As always, thanks a bunch,
Re: 17mm vs stock oil filter bolt
« Reply #1 on: February 09, 2009, 09:01:18 PM »
Never bothered
(1) Make sure you do not cross thread the bolt
(2) DO NOT overtighten
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #2 on: February 10, 2009, 01:11:09 AM »
I'm with Bryan. I fitted these on every single one of my sohc4 bikes and never had a problem.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline Steve F
« Reply #3 on: February 10, 2009, 04:16:30 AM »
Where did you get those from?
    • TVAM
« Reply #4 on: February 10, 2009, 05:59:53 AM »
David Silver Spares
SOHC4 Member #2393
Offline phactory
  • Motorcycle Rescue
« Reply #5 on: February 10, 2009, 06:07:19 AM »
I am pretty sure that Epco makes them. I bought 2 brand new ones in the packages at Barber for $15.00. I am all for originality but in this instance I will go for the 17mm head over the smaller one any day.
Phil
upperlake04
« Reply #6 on: February 10, 2009, 06:16:40 AM »
 It looks like Partnmore sells them for the 400, 550, 650 and 750K and F SOHCs also. $8-$10.
« Last Edit: February 10, 2009, 06:18:11 AM by upperlake »
Offline Alan F.
« Reply #7 on: February 10, 2009, 06:17:14 AM »
A little anti-sieze on the threads will help out too.
Offline mycb750k6
  • Rocketman
« Reply #8 on: February 10, 2009, 06:27:57 AM »
Thanks guys, I'll leave it alone. I like the anti-seize suggestion though. I also noticed the threads on the 17mm are no where near as nice as the stock if you look at the picture. I'll use the anti-seize and use the torque value to tighten.
Offline mycb750k6
  • Rocketman
« Reply #9 on: February 12, 2009, 06:17:24 AM »
Just to finish this off, I looked at a buddy's 17mm and his had the beveled holes just like the stock so I guess it really does matter where you get them because they are not all the same and apparently his seller thought the bevels were important. My advice would be to look closely at the picture if you're looking to buy one.
charlevoix418
« Reply #10 on: February 12, 2009, 06:24:25 AM »
I thought that, according to readings on the site, bigger head should not be used because it can bring you to damage threads into engine case.  It seems that Honda preferred a stripped bolt head than a stripped engine case.
Raynald
Offline mycb750k6
  • Rocketman
« Reply #11 on: February 12, 2009, 06:31:23 AM »
I think everyone including Honda has learned form this.
The larger bolt head allows easier removal of stuck threads.
This forum thread states using a lubricant or anti-seize on the threads when you reassemble and don't over tighten and use the correct torque setting and you'll be fine. Remember the O rings provide the seal, not the tightening.
