Author Topic: Changing over to Vacuum operated??  (Read 3714 times)
Offline LoopsAndLogic
  • Dang IT!!!
« on: February 10, 2009, 12:00:03 pm »
Since the weather is starting to break here in Ohio, I'm rushing to get my 400F ready for the riding season.
But after taking a spare petcock that I know works (1980 GL500) to put onto my 400F's tank,
 I noticed that the threads are the same size, but the GL's threads are fine, where as the 400's
is course.
Is there anyway to get my threaded nut onto the GL's fuel valve??
Does anyone know of a Vacuum operated petcock that has the same threads??
Maybe a CB750F???
I could really use the help, as this add-on was my plan for the entire winter :-[ :-[
Cheers
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
Offline GammaFlat
Re: Changing over to Vacuum operated??
« Reply #1 on: February 10, 2009, 02:44:38 pm »
I think a vacuum operated petcock is a great idea for these bikes.  Every time I think about it, I am stopped by the notion of "what happens when you get low on gas?"  The reserve concept works on these bikes and those bikes that have vacuum operated petcocks usually have a gas gauge (including Yamaha Razz scooters... hmmm, there's a place I can steal a gauge).  hrumph.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline GammaFlat
« Reply #2 on: February 10, 2009, 05:09:48 pm »
now we're talkin'
K6
K7
Offline detdrbuzzard
« Reply #3 on: February 10, 2009, 05:33:06 pm »
my nighthawk 450 has a vacumme operated petcock also but it still has the stop, on and reserve settings
'75 cb750k, '79 cb750/9k,'84aspencade '93gl1500se, '79cb 750f '85 cb450 sc '05 sunL 70
fuzzybutt
« Reply #4 on: February 10, 2009, 05:58:06 pm »
the xs850 has a vacuum operated petcock that has the same spacing for the screws that the earlier cb750's had, when they fastened with 2 screws.
Offline BeSeeingYou
« Reply #5 on: February 10, 2009, 05:58:34 pm »
Yamaha used vacuum petcocks on the XS650 from 78-85 and I am sure on other bikes too.  They have three positions, on, prime, and reserve.  Prime allows a continous flow of fuel and is only used to fill the carb after the bike has sat long enough for the fuel to evaporate.  Reserve works the same as any other petcock.  In the on position fuel only flows as long as the bike is running and becomes in effect the off position when you shut down.  Having lived with them for 29 years on my XS650 I can say that I really like them.  In this time I have rebuilt mine twice, replacing the O ring and whizzer valve.  I still run the original vacuum diaphragms.  I have never been a big fan of non-vacuum style petcocks because if you forget or just get lazy you are relying on the needle valve to shut off the fuel flow.
I am not as familiar on this point about Hondas.  Which models and years have vacuum petcock?  I am about to get my hands on a 76 750F.
Offline eurban
« Reply #6 on: February 10, 2009, 06:29:40 pm »
My experience with the factory vacuum operated fuel safety device (an inline fuel valve that only allows the flow of fuel from the tank to the carbs when vacuum is applied) on an 81 CB650 was that it made starting an extra long procedure with no provision for priming and caused fuel starvation issues when it began to fail.  I removed this critter and starting was quicker.  I am in the habit of turning off the petcock when I shut off the bike and don't miss the vacuum device at all.
Offline Alan F.
« Reply #7 on: February 10, 2009, 06:34:53 pm »
My 92 750 Nighthawk has a vacuum operated petcock, it threads onto a threaded bung on the left side of the tank.  Sound familliar?
91-03 were identical
Offline Soos
« Reply #8 on: February 10, 2009, 07:26:05 pm »
The CB650 uses an automatic petcock (vacuum opperated) that goes inline between the original petcock on the tank and the carbs. You only ever have to touch your tank petcock to switch to reserve, or, turn it off to remove the tank.
But only on the CV carbs...
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline BeSeeingYou
« Reply #9 on: February 10, 2009, 07:50:38 pm »
Yamaha vacuum petcocks from a 79 XS650.  These are a right and left versions and there is also a  version with a 90 degree fuel outlet.  Hole spacing is 45mm and they use a 6mm 10 pitch machine screw threaded into the tank. No threads on the petcock itself so a different screw could be used.  They take the vacuum feed off the carb boot.  Rebuild kits for the rubber parts and diaphragm are readily available.
  • Dang IT!!!
« Reply #10 on: February 11, 2009, 12:56:05 pm »
Guys, I need to know which one has the same threads....fine or course???
Can anyone take a snap shot of there threads on there CB650?? Or 750??
I know this is a lot to ask for, but the junk yards what big $$$ which is bull, and
any ebay seller won't waste his time.
Kinda in a pinch now.....
My rides:
Past Rides:
  • Dang IT!!!
« Reply #11 on: February 14, 2009, 01:06:06 pm »
bump...
My rides:
Past Rides:
Offline Alan F.
« Reply #12 on: February 14, 2009, 08:00:26 pm »
Sorry dude, the NH is put up for the winter with a full tank... but the threads looked like later model sohc4 if I had to guess.  Maybe Pingel makes a petcock that's threaded correctly?
  • Dang IT!!!
« Reply #13 on: February 23, 2009, 09:37:12 am »
Whats Pingel??
Thanks
LL
My rides:
Past Rides:
