Author Topic: Supercharging with a Drouin  (Read 9792 times)
Offline MtnPwnd
Re: Supercharging with a Drouin
« Reply #25 on: June 20, 2013, 07:18:52 PM »
I realize this thread is stupid old but what carb is he running here? I just got my drouin and it's got the mechanical injector on it.
1974 CB970K Supercharged Project http://forums.sohc4.net/index.php?topic=120708.0
Offline 23tbucket
« Reply #26 on: June 20, 2013, 07:35:04 PM »
Supercharged and fuel injected for around $2500.00
http://i258.photobucket.com/albums/hh280/23tbucket_2007/023-5.jpg
Supercharger is "Asin" rootes type positive displacement 500cc per revolution running at crankshaft speed. "Asin" also makes a 300cc per revolution supercharger. Very well made blowers. These superchargers can turn in either rotation. They show up on ebay every once in awhile. I got mine from "Japan Auction".
The engine is stock automatic with the stock low compression pistons and stock camshaft. The automatic camshaft is a good one to use for turbocharging or supercharging.
The fuel injection throttle bodies were adapted from Suzuki GSX R600. "Microsquirt" ECM.
« Last Edit: June 20, 2013, 07:51:06 PM by 23tbucket »
« Reply #27 on: June 20, 2013, 08:51:14 PM »
Gday 23, hows the injection going mate..?
« Reply #28 on: June 20, 2013, 09:02:40 PM »
Do you mean a Hilborn injector??? Pictures please...
Offline MtnPwnd
« Reply #29 on: June 25, 2013, 11:29:29 AM »
The pictures are included in my build thread. Take a look! Let me know what you think!
« Reply #30 on: June 25, 2013, 08:01:26 PM »
I certainly didn't see anything that looked like a Hilborn, or any other fuel mixing device, for that matter. It looks like a throttle cable is attached to the blower? Where does it go? How about a pic of the intake side of the blower?
Offline shpwrk
« Reply #31 on: March 16, 2014, 05:06:48 PM »
Hello   I am in the process of doing a Drouin build. I have some instructions for installation and will photo how to replace the old bearings.... Just need to know how to post photos..  The following is what I am going to do with regards to engine strength. After market rods, under cut gears,. I am using a blower cam from Web cam.. Can also use a stock 74-76 cam.stronger clutch springs are a must. Because of the extra heat use hi test gas. I will also consider an oil cooler. Will start project next month with a complete installation of new bearings and some buffing.
Pete Caroselli
Offline shpwrk
« Reply #32 on: December 11, 2015, 03:10:50 PM »
  I have completely rebuilt a drouin for my 1974 CB.  This project takes time and a lot of time and money to do..
  The FI original injection is poorly made and I would build a manifold and set up with Carb. The instructions say you can put right on to a stock bike???? I don't see how with the injection and the weak set up mounts....  A LOT of fab work is necessary to the blower work.... Complete rebuild of blower with new bearings is the first step. Second you have to make a bracket to like up blower with gear drive. All your parts have to be machined to acquire specs.
I am getting much stronger rods and custom 8-1 J&E Pistons..   New every is new for head mild port job and 3 angel cut.  The motor has to be built {bullet proof}
Not for everyone but a blown bike is just bad ass...
Pete Caroselli
Offline Bill/BentON Racing
    • BentON Racing
« Reply #33 on: December 11, 2015, 10:08:25 PM »
I ran one, and bought one from RR a few months back. They could work on a stocker, cam and pistons. Max 10 -12 lbs boost. Did lose about 30 psi compression in a 1.5-2 years I ran it! The fuel delivery can be improved with a carb done right, but the lakes style injector does ok. Definitely need a push /pull cable set up. But always drew a crowd! Bill More boost is available,  not sure if it'll hold up to even more though, G'luck,  Bill
BentON Racing Website
BentON Racing Facebook
