Author Topic: Anyone seen this Accell Ignition for 4s?  (Read 1762 times)
« on: February 11, 2009, 08:54:10 AM »
Looking through old mags and see that Accell built what they called a Superplate or Superbreaker. Quite similar to Maxi-Dwell, and they built them for a lot of 4 cyl bikes.
I did see the old ads for Maxi-Dwell and noticed that they claim 20,000 plus miles on yor point sets. I did find them to be way less adjusting & longer lived, than stock points..
Offline OldSchool_IsCool
  • Really feeling like an
Re: Anyone seen this Accell Ignition for 4s?
« Reply #1 on: February 11, 2009, 09:34:29 AM »
Hmmm a points saver.  Could this be something similar to the Hondaman Points Amplifier?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #2 on: February 11, 2009, 10:05:07 AM »
naw, they just used Chevy points, they are built different than the short Honda ones. They did use solid state condensers on the one I run, they are about the size of a Chicklet, and mine lasted 20 years..
Offline kayaker43
« Reply #3 on: February 11, 2009, 03:43:19 PM »
Hmmm,.. I worked at a Honda dealer in the 70's and never heard of the accell units? I have a couple maxi-dwells and love them, especially the one with the built in timing light.
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #4 on: February 11, 2009, 05:03:43 PM »
what does a maxi dwell look like?  I have never seen one.  I have never seen a complete Accell unit...only pieces.
MATT
Offline doobiebro
« Reply #5 on: February 12, 2009, 01:31:05 PM »
The Maxi-Dwell is very similar to the stock points plate, but uses Chevy V8 points and a small capacitor.  It also has a built-in timing light.  There is a deal on a Maxi-Dwell on e-Bay now: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=280310979102
I have one on my 1977 750K and really like it, although I have nothing to compare it to.  Nor have I done any dyno runs or electrical measures to verify if it provides any better performance than a stock points plate.  To me it simply makes it easier to time, the points are heavy duty, and points are cheaper and easier to find than stock.
« Last Edit: February 13, 2009, 07:59:25 AM by doobiebro »
« Reply #6 on: February 12, 2009, 07:35:30 PM »
And they last a very long time..
The Maxi, a bit surprisingly does not allow second set of points to move independent of the 1st. It seems to work well in spite of this.
The Accell I think has a moveable second set. I was thinking, since it was a large company that sold other bike stuff, there should be a few out there?
Offline doobiebro
« Reply #7 on: February 13, 2009, 08:03:43 AM »
Although the Maxi-Dwell does not come with the ability to move the second set of points independent of the first, I made an easy fix.  Simply drill out the rivets and replace them with small self-tapping screws.  Or you could tap the hole and use machine screws.  With this, you can loosen the screws a little, adjust, and then tighten them down again.
Offline TheHun
« Reply #8 on: February 13, 2009, 04:17:24 PM »
I just won that Maxi-dwell for 11 bucks :) it has the built in timing light :)
1978 Honda CB750-K
CBR F3 Coils
Kerker 4.1 Header w/ turn down
Maxi-Dwell Ignition
Foam Air Filter Pods
Superbike bars
Starter Delete
CARB CLEANING/REBUILD: http://www.wix.com/TheHun/CarbCleaning-Site
Not Running to Running, doing the work yourself= Priceless
« Reply #9 on: February 13, 2009, 04:27:06 PM »
Damn, I missed it! I always wanted one to add to my aftermarket ignition collection, if anyone has one they want to sell, let me know?
Personally, my favorite is my Martek 440, it's done service in 3 CB750's and a Suzuki GS750, and is still going strong after 30+ years.
When I had it in the GS750 (I took it out before I sold the bike) I could get that bike to happily idle at 250 RPM, such was the power of the mighty Martek! ;D
Offline Joel
« Reply #10 on: February 13, 2009, 05:36:24 PM »
Aren't all non-variable capacitors solid state?
