Author Topic: Greatest year of CB750  (Read 24192 times)
eldar
Re: Greatest year of CB750
« Reply #25 on: February 11, 2009, 04:30:23 PM »
Who cares if they complain anyways! Not their bike and if it was not for cutting things and customizing, bikes would all look the same! ;)
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #26 on: February 11, 2009, 04:51:59 PM »
I like 750's in general, that's why I've got three riders, and a couple more in the works, and they all have their merits. I like my 75F the most, but thats the one that has the most engine and suspension work done to it.
If its a pristine example of a particular year, I shy away from cutting them up, as they are getting to be historical pieces of machinery that are getting harder to find in stock form.
If its a pile o' parts, or a really ratty bike, cut away, and make it your own.
In the end, ride what makes ya smile... :)
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline stresssolutions
  • 4 years on a motorcycle, Time Flies!
  • 03 RoadStar, I miss my Honda
    • bloggy thoughts
« Reply #27 on: February 11, 2009, 05:53:13 PM »
Figure out what year the most were made and get one of them.  Or maybe 2 of them.  spares...
Enjoying life, one day at a time.
billybobobrain
« Reply #28 on: February 11, 2009, 05:57:58 PM »
Why bother with a particular year 750 the 400 is a much better bike from any year of pruduction.  ;D
I don't think your opinion counts mister 400 ;)
« Last Edit: February 11, 2009, 06:03:09 PM by billybobobrain »
Offline Magpie
« Reply #29 on: February 11, 2009, 06:09:45 PM »
1971 because you get a trophy!
Cliff.
Offline deacon
« Reply #30 on: February 11, 2009, 06:19:44 PM »
If you are going to modify it into a cafe racer, then the year really doesn't matter that much. Just find a low millage bike that's clean and cheap.
Offline moham
  • .fnord.
« Reply #31 on: February 11, 2009, 06:37:03 PM »
Cliff.
Cliff, are you on the left or the right? (depending on the answer, I might need to get your #...)
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline Johnie
« Reply #32 on: February 11, 2009, 07:22:08 PM »
Cliff.
1970 because you get 2 trophies.  Oh wait Cliffy, you do have 2 trophies.  You dog you... ;D
« Last Edit: February 11, 2009, 09:46:53 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline PxTx
  • See sig for possible trade?
  • Subs of Philly
« Reply #33 on: February 11, 2009, 07:28:51 PM »
I only consider 1969-1976 for a CB750.  The early ones tend to bring bigger money but I don't know if that means they are actually more desirable.  The later ones tend to have some refinements (read minor problems) worked out.  I would consider a 75 since it still allows you to turn the headlight off and is more refined.
Getting back to the desirability vs dollars on ebay.  Someone else mentioned buy whatever one you find in your price range.  To be honest they are all great bikes so I would agree.  Any of the 69-76 are cool to own.
Offline UnCrash
  • Pass
    • My Blog
« Reply #34 on: February 11, 2009, 07:44:40 PM »
 :P PXTX
I have a 76 and a 78F.  I'm caffinating the 78F for a couple simple reasons.  More HP and better carb action, dual disks up front and a disk brake in the rear.  The 78F motor does suffer from valve guide wear, but many of the current ones you'll find have been repaired under factor warantee for the work.  I also like the longer tank of the 78F for a cafe bike.
But these are my personal opinions.
Overall I do completely agree that you should spend less than a grand for the bike which you'll cut up, paint up, and tear up the roads with.  You'll put enough of your hard earned dollars in after the initial purchase no matter what year of SOHC you go for.
eldar
« Reply #35 on: February 11, 2009, 07:48:48 PM »
Problem is that there are fewer under a grand now. The cb is coming back into style cause of its history.
Offline Magpie
« Reply #36 on: February 11, 2009, 08:00:22 PM »
Nice two Johnie - and your's are bigger too! I can only hope my K0 turns out like that. So maybe K0 is the best year!!
Cliff.
By the way, as if you didn't know, I'm the O.F. in the middle of those 2 beauties.
Offline bender01
« Reply #37 on: February 11, 2009, 08:01:28 PM »
71 - 76 so as not to step on K0 restorations and easier carbs. Lots more parts compatability In my opinion.Im in SC so please help me find a $700-1000 71-76 . 75 planet blue preferably. Your in CA and it seems that warmer areas are dry of old hondas as either they werent as populated 30 years ago or the bikes have been worn out. Id buy a stock 77-78k in a heartbeat as for all the f models in stock trim. If your going to alter the look than those bikes if theyre missing cosmetics would be the way to go. IMHO..Good luck,cant wait too see your new bike.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline phactory
  • Motorcycle Rescue
« Reply #38 on: February 11, 2009, 08:45:53 PM »
Andy,
 I agree completely! Or at least completely with the 1971 part! When I decided to get a CB750 ( and I think this is a decision that EVERY REAL motorcyclist must come to at some point in his riding career  ;D) I settled on a K1 because it had been updated from the K0, especially the carbs and it also still had the headlight shell and headlight ears painted the unit color.
 K0 prices have just gone through the roof. Now if I had found a K0, especially one as complete and in the same condition of my K1, I would have surely bought it but I didn't. Oh well...
Phil
Oh come on this is easy enough...it would be a 1971 or early 1972 CB750  ;D (the 69s clearly are too expensive  ;)).
Offline Johnie
« Reply #39 on: February 11, 2009, 09:45:07 PM »
Bender...tell me why you like the 77-78 so much.  I have a line on a stock 77 that I sold to a guy.  He wants me to buy it back as he is into HD now.  Just wondering your thoughts here.  Buy the way, I also like the 75 planet blue...so much so that I have an NOS 75 planet blue tank in the basement in case I ever find one.
Oshkosh, WI  USA
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
« Reply #40 on: February 11, 2009, 10:58:30 PM »
I recommend the '77-'78F models for these few reasons. 1. They are more likely to be found for cheap than an earlier one.  2. They have more braking power.  3.  The front end is compatible with dohc 750's and since they are cheap and easy to find wrecked, there's no shortage of parts.  ie. brakes and forks.  4.  More power=more speed.  5.  The black motors are sexy.  6.  Those bikes are horrible looking stock.  They need help.  7.  It's what I ride.  8.  Fill in the__________________.
78SS out.
333:  Think "Shakeweight".
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #41 on: February 12, 2009, 07:03:25 AM »
2009, definitely the best year for Honda CB 750's.
Offline bender01
« Reply #42 on: February 12, 2009, 07:25:16 AM »
Johnie. I dont have a 750 so any would be fine. 77-78 if theyre all theyre because I think theyre cosmetic pieces are harder to find. I prefer 71-76 k models myself. They just look right to me. WI is a long way from here.. Are you vacationing to Hilton Head soon? Bring it with you.
75 550 K1
74 750 K4
74 750k 836 project
Good luck!
Two Tired Quote !
Offline cxtecs
« Reply #43 on: February 12, 2009, 11:17:00 AM »
Allow me to chime in, but since this is my first official post, let me give you my credentials:  I've owned my 78 cb750 for less than a year, and I am going cafe style with the bike.  I've also recently acquired at 77 parts bike (another K model). My riding goals seem similar to your's: cool looking (ie. cafe racer) commuter bike (ie. reliable) that's also fun to ride (ie. with balls). I buy most of my parts from ebay. I've got a pic of my cafe project on this thread:
http://forums.sohc4.net/index.php?topic=33548.msg482761#msg482761
sohc4 experts, please correct me if I'm wrong on anything that follows.
Now what you are willing to deal with determines the answer to your question (to quote other posts in this thread -"it's relative".)  You probably shouldn't be looking for a 69 or 70, as those are considered highly collectible, and I respect the 750 too much to ever want to cut one of those up.  Addtionally, the collector value on those would be much higher than the prettiest cafe racer you could ever build. K0 and K1 have sold for $5000-$15,000. Most cb750 cafe racers I see being sold only fetch $2000-2500 at the most unless they are made by Steve Carpenter.  Parts for these bikes are similarly expensive if even able to be found.
72-76 would probably be the best choice.  Lots of stuff available for those including carb kits, sprockets, spoke kits, exhausts, and body work with most of the aftermarket cafe seats made for the 750 will accomdate the hinges and locking mechanism on those bikes so your cafe seat will open/close/lock down just like the stock seat (77-78 hinges are on the other side).  The stock tanks look cool too with those flip top gas caps.  If you're into cafe racers, then you should know Carpy, and he almost exclusivley only messes with these year bikes. The K frames on these bikes are among the shortest of the 750 sohc series  (77-78 and the F bikes will most likely have some frame tabs (turn signal/rear fender mounts) extending out from the bottom of your cafe seat -I had to chop mine off on my 78).  The 77-78 K models were designed to cater to the touring market, so they got longer, more rigid (ie. heavier) frames and Honda designed the F models for the sport market (supposedly thinner walled tubing on the frame (ie. lighter).  I think the F model frames might be longer also.
77-78 were probably the most reliable 750sohc engine (except for the late F model). Any refinements Honda could do the the sohc750 engine were done to the K7-K8 motors (3 piece oil rings, increased oil cooling, heavier duty 630 chain, etc.) Parts are a little harder to find, but since there were fewer of these bikes, the parts are in less demand (ie. cheap).
The F models seem to be the least desirable of the sohc750 bikes.  In my area, you can typically find them for about $200 cheaper than the same year K model.   The 1978 F3 had the most performance enhancements designed into it including the bigger valved but questionable valvetrain.  Three disk brakes are cool, but from what I read, the single disc/drum brake set up already performed well.  I have dual fronts discs on my bike, but I did a GL1000 conversion to also get the benfit of larger diameter forks and aluminum rimmed wheel.  Also regarding the F3, the cafe look becomes hard to achieve with the the stock ComStar wheels.
Offline 736cc
« Reply #44 on: February 12, 2009, 12:08:44 PM »
Any year sandcasts/K0's and K1's w/ stock HM300 pipes win. That SOUND not to be underestimated.
[/URL][/img]
Offline lordmoonpie
    • Moonpie
« Reply #45 on: February 12, 2009, 12:25:13 PM »
1968
I'm with Johnny - 1968, I like my 750s kind racey looking  ;D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline Slayer
  • What can I say that hasn't been said before
« Reply #46 on: February 12, 2009, 01:19:53 PM »
Hey thanks cxtecs it looks like your project is coming along well. What did you do with that seat, that thing is a beast! Well I have one strong offer but it is a bit steep. It is for a 71 that is in very good running condition with new paint and a stock seat for $2,500. I dont have a pic but it is exactly what I am looking to start out with since it is getting chopped up anyway I am not worried about cosmetics so much. Is the extra $1,500 worth a reliable engine? It seems so to me, but I am very anxious and I don't want to impulse buy. I am still waiting on my settlement for getting creamed on the freeway on my Bonneville so I am still going to have to wait anyway but it feels like I am going through bike withdraws. I don't know how the east coasters do it during winter. Props!
« Reply #47 on: February 12, 2009, 04:13:55 PM »
You have asked an open ended question. You are not talking about a particular bike, you are talking about a model name that had a 9 year run. Each year small changes were made internally and over a period of time the styling. If I park my 78 next to a 69, except for the motor they look very different. It is a matter of what you can afford. As said before, of you are modding it out, anything would work.
