Author Topic: ahhhhh it doesnt end  (Read 1725 times)
Offline andy8190
« on: February 13, 2009, 04:37:12 PM »
so i got the bike running and running fine it seems. well today i come in the house and it smells like so much gas. I go in the garage and sure enough there is a sh** ton on the garage floor. the carbs are now leaking gas out of the over flow. i know this is prolly float height adjustment so i am gonna tackle that first. I also think i have some leaking coming from the screws coming at the bottom of the bowl and also the bowl gaskets this blows. Anyone out there just have a set of great carbs just laying around haha?
Offline OldSchool_IsCool
  • Really feeling like an
Re: ahhhhh it doesnt end
« Reply #1 on: February 13, 2009, 04:41:21 PM »
How clean is your tank?  Could a chunk of gunk have gotten into the needle, holding it open?  Try draining the bowls, then tap the bowls with the butt of a screwdriver as you refill them.  Maybe you'll knock the crap loose.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline andy8190
« Reply #2 on: February 13, 2009, 04:41:55 PM »
also on that note i am looking at hondaparts-direct at float bowl gaskets #1 on the carb fiche, is that "set" come with 4 or is that 10 dollars just for one gasket?
Offline andy8190
« Reply #3 on: February 13, 2009, 04:42:58 PM »
i dont think it could be anything in the tank because i just por15'd it but i will also try that. gonna put some sea foam in the tank too.
Also on the fiche it doesnt look like you can buy just the washer that goes in with the screw at the bottom of the float bowl, does anyone know anything about these. i dont need new bowls just those screws and washer
Forget the washer question i was looking at the wrong number i noticed
« Last Edit: February 13, 2009, 04:48:35 PM by andy8190 »
Offline KB02
« Reply #4 on: February 14, 2009, 05:59:07 AM »
I highly recommend getting used to using your fuel valve.
On my old F1, 90% of the time I was fine if I left it on. That last 10% of the time, though, it made me not want to turn on the light in the garage for fear of sparks in that fumey atmosphere...
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline fmctm1sw
« Reply #5 on: February 14, 2009, 11:29:34 AM »
Mine did exactly the same thing.  Turns out the fuel petcock keeps putting fuel to the carbs.  The "off" position is simply a recommendation to it.  I figure that rubber ring inside it is worn.  I'll get to it some day soon.  For now, I disconnect the fuel line and have another fuel line with seal all plugging the end.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #6 on: February 14, 2009, 11:37:41 AM »
If you routinely park on the sidestand, make turning off the petcock part of your routine for parking in the garage.
My 77 550 STILL pees on the floor occasionally.  And, this is almost guaranteed when the tank has just been filled.
I still forget, sometimes.  Mostly when the routine is broken.  ::)
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #7 on: February 14, 2009, 11:42:28 AM »
Yep, I got tired of that aromatic smell wafting into my living room (and I changed the float valves!). When it sits for any amount of time I just turn it to off, saves on wasted petrol.
Offline andy8190
« Reply #8 on: February 14, 2009, 01:14:28 PM »
i picked up some neoprene washers today at home depot and gonna try those out on the petcock first then i am gonna tackle trying to fix the needle problems on my leaking carbs. Also i got some o-rings from there and gonna try those out on the float bowl drain screw, dont know if they are fuel resistant but they will work till i find some more im sure (if they are the right size that is)
Offline andy8190
« Reply #9 on: February 14, 2009, 01:42:30 PM »
well the neoprene washers worked on the petcock it no longer leaks
Offline andy8190
« Reply #10 on: February 14, 2009, 04:16:18 PM »
ok so i got the carb floats to stop leaking for the most part, now the final thing i need is float bowl gaskets or o-rings because mine are flat and it looks like there is fluid coming from there just a hair though.
