Author Topic: cb550/c50 camswap worm gear q  (Read 1042 times)
Offline d3buttz
  • More than just an
« on: February 15, 2009, 10:45:23 AM »
has anybody tried to just swap the worm gear from a 650 into a 550 cam cover? or is it pressed/permanant/ unreplaceable? seems easier/cheaper than going the electronic tach route.
and, if i cant swap-how do i remove it?
« Last Edit: February 15, 2009, 10:55:54 AM by d3buttz »
http://forums.sohc4.net/index.php?topic=80508.0
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1996 Nissan pathfinder
1972 Datsun 240z
2002 Nissan sentra se-r spec-v
Offline youngerthanmybike
Re: cb550/c50 camswap worm gear q
« Reply #1 on: February 15, 2009, 10:58:22 AM »
If I remember right, isn't it just attached by a screw on the outside of the housing?
I don't remember it being much of a puzzle to remove.
Offline d3buttz
  • More than just an
« Reply #2 on: February 15, 2009, 11:26:47 AM »
oh! duh.  ok i got it out, is a 650 worm gear a direct replacement(part numbers are different)? im also sure i have to go with a 650 tach.
i did some searching-650 cam worm gear will fit in the 55o according to a 650/550 hybrid forum.
« Last Edit: February 15, 2009, 12:33:22 PM by d3buttz »
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1972 Datsun 240z
« Reply #3 on: February 15, 2009, 02:20:08 PM »
FYI, just because I've been going through some of the same research, etc that you are-
You probably already know that the 550 has a different tach ratio (is 20:3) from the 650, BUT
the 750 is the same ratio as the 650, which is 4:1, which there are also a number of aftermarket parts for. I say that because I think there's a few more 750 parts out there than 650 parts..... ;D
Good luck with the rest of the swap!
