Author Topic: Tips and tricks for removing the tire without doing damage.  (Read 1528 times)
Offline Toxic
« on: February 15, 2009, 11:09:52 AM »
Hi there
Did a search for "tire removal" but it didn't turn up what I was looking for.
Mainly good infor on how to break the bead though.
I didn't have a problem with the bead it was in removing the tire from the rim using the tire irons that I totally buggered up the edge of the rim.  The rim is nicked quite badly every place I put the iron.  After 12 inches came off then it was easy. But it is so difficult for the first little bit the force required on the irons does lots of damage.
Is this a case of bring it to the dealer as they have the proper equipment to do the job properly?
I have sourced another rim and don't want to repeat the same disaster.
any help would be appreciated./
Gary
Offline Gordon
  • 750K1, 550K2
KingCustomCycles.com
Re: Tips and tricks for removing the tire without doing damage.
« Reply #2 on: February 15, 2009, 12:19:33 PM »
Flat tire "spoons" will work. JC Whitney sells them.   I have cut them off with a sawsall and side cuts. Since I am old, feeble, and weak, I now take them to the local bike shop.
Offline Toxic
« Reply #3 on: February 15, 2009, 01:47:26 PM »
You need to get some rim savers.
http://www.jpcycles.com/groups.aspx?LID=5B6FD4C2-AEAA-475F-A072-04F10E02C131&DID=46501906-2DB8-48BD-BEEF-188D2D6138B4
Wish I had of know about these. ???
Last time I changed my own tire on a bike was 30plus years ago.
On the positive side I guess I will have a spare set of spokes, speedo drive,etc.
The replacement rim is actulally better than the current one I have.
Hey now I will have two disks , umm maybe time for a dual disk upgrade.
Thanks guys
Offline Hinz
« Reply #4 on: February 15, 2009, 01:52:42 PM »
nah, don't bother. I bought the rim savers and the 11" flat tire spoons. In the end, I ripped the rim savers in half and scratched up the rim anyways.
If you really don't want to hurt the rim at all, then take it to somebody with a machine.
1976 CB750K
Has learned so far that..."complete" gaskets are never complete no matter where you get them, VHT Silver Case Paint is just as durable as painting your motor with chalk and cheap tire irons used with rim protectors are useless on 30 year old tires.
Offline jason teamshralp
« Reply #5 on: February 15, 2009, 10:39:57 PM »
cut up some plastic juice cartons into strips and fold them and then pry slightly on the tire. if you feel it getting too much tension, stop what your doing, and take it to a shop that does this all day long.
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: February 15, 2009, 11:02:53 PM »
Not sure how you managed that...
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #7 on: February 16, 2009, 08:29:04 AM »
+1 on the milk jugs. Those bent emgo irons work well but only if you round them off with a grinder to the radius of a nickel on the ends. Jim at Cyclops helped me with that one.
